Author Topic: transmission swap  (Read 5225 times)
Offline chrpmaster
transmission swap
« on: March 16, 2009, 04:40:21 pm »
I was wondering how many problems I would cause for myself if I put a 700r4 from an 82 4 wd on my 76 c-10 2wd?
Re: transmission swap
« Reply #1 on: March 16, 2009, 04:47:44 pm »
You would have to tear the 700R4 completely down to swap a 2WD output shaft.
Offline chrpmaster
« Reply #2 on: March 17, 2009, 09:50:16 pm »
Does anyone have diagrams of the 2wd and 4wd.  I am trying to understand the difference between them.
Sorry for the newbie questions
« Reply #3 on: March 17, 2009, 09:56:25 pm »
The same except the output shaft is shorter on a 4x4 trans.
Offline werewolfx13
« Reply #4 on: March 18, 2009, 12:17:06 am »
Swapping output shafts isn't hard if you have a clutch press and know your way around a transmission at least a little bit. Going that far into it, I'd rebuild it and do the much needed mods.
Chris
'83 Chevy c10 Silverado SWB
Offline chrpmaster
« Reply #5 on: March 18, 2009, 08:11:11 am »
I found a 700r4 from a 2 wd s10 blazer on Craigslist.  Supposedly it was recently rebuilt.  Would that be the same as one for the full sized pickup?
Offline 406 Q-ship
« Reply #6 on: March 20, 2009, 01:39:01 am »
The S10 has to be from behind a 4.3 V6, the other V6 uses a different bellhousing pattern.  All the 700r4 will bolt in to a truck, the TH350 with a middle lenght tailhousing uses the same driveshaft.  A 700 from about 88 to 92 are the better choice, they have the best interials for the last of the non-electronic 700's.  I got my 700r4 out of a 1991 G10 van and slipped it in an afternoon, my 74 truck had the middle lenght tailhousing so it was a simple trans swap.  Oh yea I had to modify the shifter linkage slightly to get to smoothly go through the gears, I bet the later trucks the shifter linkage will work fine without mods cause these trucks got the 700 in 84.
« Last Edit: March 20, 2009, 05:49:55 am by Blazin »
The difference between genius and stupidity.......Genius has limits.
Offline chrpmaster
« Reply #7 on: March 20, 2009, 08:20:27 pm »
Couldn't I just use the drive shaft from the donor truck?
