Author Topic: Will the caltracs work with this setup?  (Read 4480 times)
Offline Chevalade
« on: March 20, 2009, 02:36:58 pm »
Thinking of fitting poor man fatties on the back of my 81 2wd sb, by boxing the frame and swapping rear springs side to side on the inside,with a 3/4 drop. Would the caltracs also be able to swap sides and work on the inside of the frame?
Any thoughts on this would be appreciated.
Ryan
Offline HAULIN IT
Re: Will the caltracs work with this setup?
« Reply #1 on: March 20, 2009, 03:50:40 pm »
Sure, They are the same...just like a pair of socks! Be sure to get the correct ones (flip or non-flipped) based on where you put your axle (flipped ;)) Check with Chris...he is a distributor for Calvert products. Lorne
Offline Chevalade
« Reply #2 on: March 20, 2009, 04:43:23 pm »
Thx Lorne. Wasn't sure if there would be angle or alignment issues doing it that way. Now this is the way to go prostreet on the cheap.
Ryan
