Author Topic: How do I remove my smog equipment?  (Read 7273 times)
Offline JBerryhill
  • 1987 GMC Sierra Classic SWB
« on: March 23, 2009, 07:54:37 pm »
Well it's time for another truck project, I want to remove all the smog stuff on my 87........I know when I removed it from my 90 Mustang GT I had to plug some holes in the heads, are these the same or do the tubes just come out of the manifolds? will this mess with my EGR or do I remove it also? once again thanks for any help.
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
Re: How do I remove my smog equipment?
« Reply #1 on: March 23, 2009, 10:18:56 pm »
If you have TBI, the only thing you can get rid of is the A.I.R. Pump and lines and maybe the egr system.
Offline gold84gmc
« Reply #2 on: March 25, 2009, 04:16:41 pm »
i did that on mine and i took off the pump and lines....then just put plugs in the exhuast manifolds where the lines went...it didnt affect how it runs
92 buick century custom 3.3L
Offline JBerryhill
« Reply #3 on: March 25, 2009, 05:35:44 pm »
Just behind the air pump there is a valve of some sorts that has a 2 wire electrical plug in, do I just leave it unplugged?
« Reply #4 on: March 25, 2009, 05:40:17 pm »
IF you leave it unplugged, your check engine light will come on. I removed the pumps on our church bus (C60 with a 350) and the check engine light is one. I have to find out which resistor you can out in it to make the light go out, I just havent done so. When I figure it out, I will let you know. The light doesnt hurt anything, and simply removing the bulb from the dash will fix that. I think the emmissions junk is the only thing that will make it come on anyway, but I wont swear by it.
Gold84GMC, what did you use to plug the holes with. The one I did had the flare nuts on it, and I retapped the holes to put different pipe thread type plugs in it because I couldnt find flare nut thread type plugs that size.
« Last Edit: March 25, 2009, 05:43:21 pm by choptop »
