Author Topic: Engine swap options  (Read 13731 times)
Offline RockPaws
Engine swap options
« on: March 29, 2009, 08:31:22 pm »
Hi All,  My old Chevy Truck 1973 2x4 3/4 T 292 six engine 4 speed been in the family since new in late 72'.  The 292 has been a great motor and still runs great (I rebuilt it about 25 years ago).  Does not burn oil, but lacks the power it once had. Its been a great truck, now just my ranch/work truck for building our new home.  I've also considered a 4 barrel carb and manifold upgrade for the 292?  It already has a HEI upgrade.
I'm considering an V8 engine/trans swap.  I'm looking for better power and fuel mileage.
Engines? Would like enough torque to support hauling when needed, but not on a regular basis.
Would like multiport if possible, but would consider the reliable throttle body.
Transmission?  So far would like to swap in a NV4500 5 speed, but will consider a automatic.
Best donor Chevy truck?  My best route to get all the wiring and computer.
Any recomendations would be helpfull; links?
Thanks,
Frank
Offline team39763
Re: Engine swap options
« Reply #1 on: March 31, 2009, 09:30:12 am »
I'm a believer in the BBC now.  I towed my race truck with a Ford truck powered by a smallblock, and it felt like crap.  That poor truck couldn't pull up hills for crap.  Then I bought my 454 powered dually and it's amazing.  I don't really notice the weight back there.  That poor Ford needed to be floored just to maintain 55mph sometimes.  I also like the 4L80E trans, but I bet that 5spd would be nice as long as you didn't have to sit in traffic.
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #2 on: March 31, 2009, 09:58:40 am »
Quote
4L80E trans
The 4l80e trans is nice, but, you must have a 91 or later computer to control it, along with the VSS
A nicely built sbc will work just fine unless you are pulling something over say 6k lbs frequently.  With an inline 6 cylinder, you may have a higher rear ratio.  you may wanna consider lowering that.
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #3 on: March 31, 2009, 01:37:31 pm »
Look up caddy 472's and 500's.  When the time comes I'm dead set on a 500 in my '78 C20.  Higher quality parts, close to sb chevy weight and more torque stock than any 454 came with. plus I see people claiming to get 20mpg with a 3 spd tranny in a 4700lb. car.
Offline dustystrucktoo
« Reply #4 on: April 01, 2009, 12:53:25 am »
 ;D
My dad always tuned his 1972 Buck Electra 225 with the 455 engine, I do believe it was with a 400 tranny, every weekend.  He did get 20 mpg.
You can acquire a cheap engine from a U pull it, usually less expensive than trying ebay or craigslist.  ...  You might want to look for any wrecked local vehicles.
That straight 6 has the torque, not a lot of power, so any V8 350 or larger V8 will make you happy, even with that 4 speed tranny....  Small carb for fuel mileage.
The calculation for choosing a carb is listed on the Holley web site.
I don't advise revving a stock engine past the 5500 rpm, so I tend to calculate 5000 rpm being max for carb selection.
If you get a 350, go  with the 400 cfm.
I have a 600 cfm for my 400 sbc and wish I had the 500 cfm .  For a 454 chevy V* the 600 cfm is perfect for full response throughout the rpms.
More air, requires more fuel.
« Reply #5 on: April 01, 2009, 06:47:22 pm »
What about diesel? A Cummins 6 cylinder would be sweet in that old Chevy?
« Reply #6 on: April 01, 2009, 09:50:09 pm »
Thats what I want for my crewcab, just got to wait to find the right donor truck ( and the money)
Where did our resident Cummins guy go? Hadnt seen him in a while.
Offline RockPaws
« Reply #7 on: April 02, 2009, 09:23:43 pm »
Thanks for the replys!
One of my past Chevy trucks had a 454 BB Chevy,  great engine.  Wish I still had that truck! ( a 73' 1 ton 2x4)  ;D  Diesel would be great, it must be a Cummins.  But a little pricy for this truck I feel.
Maybe the 454 w/ the MPI and a  NV 4500 trans might be the best combo providing the fuel mileage is around 15 mpg. The made these in 1996. Or a 350 hoping to achieve around 19 mpg.
Not a lot to spend on this project so a donor truck would be best.
Frank
Offline rayamx69
« Reply #8 on: April 02, 2009, 09:33:10 pm »
if you are looking for mileage, i would suggest a tbi 350 from late 80s to early 90s, or a newer ls series engine. my 89 burb with the tbi 350 got 18 mpg city, and my c10 with a 5.3l carbed setup gets 15. an injected ls motor should get 20-25 mpg and and are getting pretty easy to find with low miles for cheap.
78 c10 5.3l
Offline Chevalade
« Reply #9 on: April 03, 2009, 08:20:11 pm »
425/472/500 caddy......th-400 with a gearvendors overdrive. Pull houses down, and still get decent milage.
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
« Reply #10 on: April 03, 2009, 08:58:17 pm »
Quote
Ray, you are correct there!  My 91 sub 3/4 ton 4x4 tbi 5.7 gets 17 on the interstate with a light foot.
city driving though, well, that's a different story to get that detroit metal up to speed 5 or 6 times a mile. Lucky to get 11 then--with a light foot
