Author Topic: Seatbelt plastic thingie removal  (Read 17823 times)
Offline GoatBeard
« on: April 01, 2009, 09:56:09 am »
How do you remove the plastic seatbelt cover on this thing (see pics below) without destroying it?  I need to get the bolt underneath off so I can repaint the white plastic column pieces.
Thanks!
Sam
Offline hotrod24
Re: Seatbelt plastic thingie removal
« Reply #1 on: April 01, 2009, 11:55:33 am »
you should be able to pop that plastic peace off and there will be your bolt you can use your hands very easy or use a flat head screw driver
good luck
« Last Edit: April 01, 2009, 11:59:59 am by hotrod24 »
1978 pontiac grand prix...
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #2 on: April 01, 2009, 12:21:53 pm »
it opens.  Pop out the bottom of the outer part, it hinges at the top.  once it's popped up, you'll see the rest of it is under the belt bracket, you have to unscrew the bolt to get it completely off.
« Reply #3 on: April 01, 2009, 01:41:25 pm »
Being a later model it should be hinged at the bottom...
Offline GoatBeard
« Reply #4 on: April 01, 2009, 02:16:57 pm »
It looks like the bottom of it is hinged (with plastic) upwards -- the bolt goes through the entire piece on the backside.  Since there's no hinge at the top, y'all think pulling it away from the top will allow it to hinge down where I can take the bolt out and remove the whole piece.  That sound right?
Offline GoatBeard
« Reply #5 on: April 01, 2009, 02:29:16 pm »
Awesome!  It was simple -- like y'all suggested I took a screwdriver and pried at the top of it; it popped right off and folded back.
I had done the bottom ones last year but I used the "brute force" method.  Luckily they didn't break completely off, but I didn't remember how they were attached and didn't want to use that method a 2nd time!
Thanks!
  • Z62 ON-ROAD
« Reply #6 on: April 01, 2009, 02:47:25 pm »
Sorry about the bum info, I'm having one of those days....   Maybe I'll take the rest of the day off...lol
Offline GoatBeard
« Reply #7 on: April 01, 2009, 02:50:20 pm »
Ahh heck, it made total sense to me!  But taking the day off -- that's a good idea in iteslf!  ;D
« Reply #8 on: April 01, 2009, 04:53:04 pm »
Actually it wasn't wrong info, it was just the wrong year.  Early ones hinged at the top.
  • Z62 ON-ROAD
« Reply #9 on: April 01, 2009, 10:56:16 pm »
Oh good, I was feeling like a dummy. ;D
