Author Topic: cheap 2-4" lift for 86 3/4 2wd??  (Read 12943 times)
Offline Cowman85
« on: April 01, 2009, 08:48:48 pm »
Hi i am looking to lift my truck enough to clear a set of chevy/gm 03 2500hd rims, i do the occasional trail, riverside now and then but nothing extreme.
I can get a pair of new 1 ton springs for the front, lift blocks for the back right? do i need to change out my leaf springs as well?
My main concern is the brake lines and steering arm, i'm hoping with that small of lift that i will be alright. I am a student so price is a huge factor.
86 C20 350/TH400 LWB
80 C2500 350/Muncie SM465 *gone to heaven* LWB
98 Malibu 3.1 V6
86 S10 L99/4L60E
Re: cheap 2-4" lift for 86 3/4 2wd??
« Reply #1 on: April 01, 2009, 09:31:44 pm »
The rims should clear no problem. What size tires are you gonna run?
 I dont think the one ton springs are going to help much since you already have a 3/4 ton. I have 265/75-16s on Oldyellers truck and dont have much trouble.
Offline Cowman85
« Reply #2 on: April 01, 2009, 10:16:22 pm »
not sure, they are stock 4x4 i think.
98 Malibu 3.1 V6
86 S10 L99/4L60E
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #3 on: April 01, 2009, 10:49:59 pm »
The wheels won't be a problem and I know for a fact up to a 265/75/16 tire will be fine.
I put 3/4 ton HD (or 1 ton LD, whichever way you want to look at it) front springs on mine and 1.5 lift blocks in the rear (I already had HD rear springs).
Before
After
In the front shots The angle is different, but look how the control arms angle chenged.  I haven't had any problem with it hitting the bump stops, even though it looks fairly close, and I've been on some nasty roads.
« Reply #4 on: April 02, 2009, 06:35:00 am »
Same size tires, different wheels, stock (over 500,000 mile) suspension.
Offline Cowman85
« Reply #5 on: April 05, 2009, 01:22:22 am »
i cant wait to get mine, they look sooo much better!
98 Malibu 3.1 V6
86 S10 L99/4L60E
Offline Socal_GMC
« Reply #6 on: September 25, 2009, 01:07:10 am »
So which springs do i get for my 3/4. i have the 350 in it should i just get the springs for the 454 or c30 springs for a 454??
« Reply #7 on: September 25, 2009, 06:52:31 am »
Based on new info I have been told, if you can fiind C30/454 springs , go for it. I know from experience that 3/4 ton-454 springs would help.
Offline Flamingbig10
« Reply #9 on: October 02, 2009, 10:03:58 am »
hd coils and 3" body lift on 32s
Offline gold84gmc
« Reply #10 on: October 21, 2009, 10:43:14 am »
i also have a 3/4t 2wd and i can put 32" tires with 16" rims and they dont rub on the front so you wouldnt need to put any lift at all....but if you want to i would do the 1ton springs and lift block in the back
92 buick century custom 3.3L
