Author Topic: Coolant on oil filter  (Read 4317 times)
Offline the_legend_1981
« on: April 04, 2009, 08:47:41 pm »
I noticed a little bit of coolant on the engine right above the oil filter. No bubbles in radiator or steam from exhaust. I'm thinking its a slow leak from the freeze plug right above it. How slow can those leak?
Re: Coolant on oil filter
« Reply #1 on: April 04, 2009, 11:06:15 pm »
Very slow. I had a bigblock in my 77 that the freeze plugs rotted out of it. I replace two in the truck then decided to pull it and just rebuild it. They can be relpaced in the truck, but it is a royal pain.
« Reply #2 on: April 05, 2009, 06:44:08 am »
Moroso Ceramic Sealer.
The kind that can't be used with anti freeze still in the motor works the best.
Follow the directions on the bottle or it won't work right either.
« Last Edit: April 05, 2009, 06:45:42 am by Blazin »
« Reply #3 on: April 05, 2009, 02:06:06 pm »
Quote
I saw some stuff like that...not sure if it was that brand. Thanks, I'll give that a try if I cant figure it out.
« Reply #4 on: April 05, 2009, 11:06:35 pm »
There is either Moroso Ceramic Sealer or not Moroso Ceramic Sealer. Use the Moroso or don't bother.
