Author Topic: ? about intake manifolds  (Read 6183 times)
Offline 1badazz84
« on: April 05, 2009, 12:06:29 pm »
i have a 84 GMC with a 305v8 i wonder if a EDELBROOK INTAKE 2701 with the EPS on it well work on my 305 befpre i buy one.
Offline TexasRed
Re: ? about intake manifolds
« Reply #1 on: April 05, 2009, 12:42:11 pm »
Are you running stock everything? The quadrajet won't fit on that without an adapter which will kill power.
Offline eventhorizon66
« Reply #2 on: April 05, 2009, 02:06:41 pm »
I'm running a #2701 manifold and a #1406 carb.  It's basically a tweaked #2101 designed explicitly for squarebores carbs.  I don't see why a manifold that works well on a stock 350 won't also work well on a stock 305.
'85 C10 SWB 350 700R4 TKO600
Offline TexasRed
« Reply #3 on: April 05, 2009, 05:17:49 pm »
Also, there's no EGR on that manifold, don't know if you have emissions for that truck or not.
Offline 1badazz84
« Reply #4 on: April 06, 2009, 05:31:58 am »
im not running a stock carb. i have a edelbroock carb & no EGR i think i going to use it & see whats going to happen.
Offline jlane1820
« Reply #5 on: April 17, 2009, 10:11:39 am »
Quote
Same here, on my 305. Great set-up with improved drivability over stock.
And as TXRed said, you may want to consider if you have emission checks because the 2701 is a non-EGR manifold. If so, the 3701 seems to be the only option to keep your EGR, but you'd need a square-bore adapter for the 1406 carb.
Also, another component worth considering is the Edelbrock 2101 cam kit to go with your set-up...just a suggestion (no, I don't work for Edelbrock).
« Last Edit: April 17, 2009, 10:15:32 am by jlane1820 »
Offline 1badazz84
« Reply #6 on: December 14, 2009, 08:37:12 pm »
i got a 3702 edelbrock performer plus
