Author Topic: t56 swap?  (Read 12198 times)
Offline 67Cuda408
t56 swap?
« on: April 06, 2009, 12:06:13 am »
I was just wondering wat all it would take to swap a t56 into a 80 c10? It currently has a 3 spd manual if the t56 wouldnt work are there any common direct bolt in 4 spds?
« Last Edit: April 06, 2009, 12:46:59 am by 67Cuda408 »
Re: t56 swap?
« Reply #1 on: April 06, 2009, 06:19:06 am »
Offline 67Cuda408
Re: t56 swap?
« Reply #2 on: April 06, 2009, 11:28:53 am »
I have access to a t5 from a 80s firebird would that fit into an 80 c10?
Re: t56 swap?
« Reply #3 on: April 06, 2009, 03:50:38 pm »
Will the T5 (firebird) fit, yeah, will it last probably not if you plan to abuse it  they were put behind 350's for a reason.
There are a few companies making retrofits for new trannys.  http://www.keislerauto.com/ is said to have the most compolete set of parts.
