Author Topic: 305 and 350  (Read 8157 times)
Offline murraygmc
  • 85 gmc 4x4
305 and 350
« on: April 06, 2009, 06:37:48 am »
what is the difrence betwene a 350 and a 305..???
85 gmc high serria 4x4
Re: 305 and 350
« Reply #1 on: April 06, 2009, 06:51:58 am »
The internals are slightly different in bore and stroke.  Physically they are the same in size.
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
Re: 305 and 350
« Reply #2 on: April 06, 2009, 11:47:25 am »
305 has a smaller bore than a 350, but the stroke and everything else except the heads are the same.  The heads are different because the bore is smaller.
Offline murraygmc
  • 85 gmc 4x4
Re: 305 and 350
« Reply #3 on: April 06, 2009, 02:05:56 pm »
i bought this motor in good fath it was a 350 and iv bought a lot of parts 4 it turns out its a 305 when i put it in i had the whole dog house and core suport off go it put all back togather and then i found out it was a 305 stuped me didnt check the numbers till i got it all put back togather so now i have a 77-76 305 with a 2 barrel rodchester  what is the differance in horse and just plane power from a 350 4 barrel ?
Offline eventhorizon66
Re: 305 and 350
« Reply #4 on: April 06, 2009, 03:12:11 pm »
If you want a reliable cruiser, 305s are OK.  But if you bought it to hot rod someday or need something for towing right now, get rid of it and find a 350.  The difference is about 40 lb-ft of torque @ 2000 rpm between a stock 305 and a stock 350.  Peak horsepower figures don't mean jack squat for a daily transport work truck.
« Last Edit: April 06, 2009, 03:18:48 pm by eventhorizon66 »
'85 C10 SWB 350 700R4 TKO600
Offline murraygmc
  • 85 gmc 4x4
Re: 305 and 350
« Reply #5 on: April 06, 2009, 03:44:43 pm »
o ok than i might keep it untill i get readt 4 my 4in lift and 33 12.50 s   thanks alot
Offline Russ130
Re: 305 and 350
« Reply #6 on: April 06, 2009, 05:29:50 pm »
Hmmm, and how is the stroke different?
The heads can only go up to 1.94 intake valves due to the smaller bore. However you can really wake up a 305 with 58cc combustion chambers and 1.94 intake valves. That with flat tops and a good cam will work very nicely.
Re: 305 and 350
« Reply #7 on: April 06, 2009, 06:28:46 pm »
I was mistaken on the stroke as 78 Chevyrado pointed out.
