Author Topic: EXHAUST 101:  (Read 3791 times)
Offline Stewart G Griffin
EXHAUST 101:
« on: April 09, 2009, 01:06:44 pm »
I HAve a few basic questions concerning how to piece an exhaust system together:
1) How are exhaust systems pieced together?  Specifically, how do you know/determine if one pipe/piece---i.e., muffler, converter, or pipe will fit over another?
For example in this picture, i am trying to fit a muffler or possibly an extension pipe over this opening which i've measured to be 2.5 inches.  How do i know if the muffler will fit over this pipe?  Or inside the pipe?  What if the muffler opening is exactly the same as the pipe?
2) What does "I.D." mean?
What does "O.D." mean?
Offline ccz145a
Re: EXHAUST 101:
« Reply #1 on: April 09, 2009, 01:58:20 pm »
Lets answer 2 first: O.D= Outside Diameter, I.D = Inside Diameter
Most mufflers of a given size will fit over a pipe of the same size. Expanders are used to cover the rest. Expanders are either power or manual, they fit inside the ends of the tube and, when tightened, enlarge the diameter.
Offline eventhorizon66
Re: EXHAUST 101:
« Reply #2 on: April 09, 2009, 02:30:14 pm »
You know what'll fit after you give it a try.  When joining two lengths of pipe of the same size my exhaust shop uses a pneumatic expander.  I have a manual expander and it works but you really have to strong arm it with a 18" breaker bar.
« Last Edit: April 12, 2009, 02:01:30 pm by eventhorizon66 »
'85 C10 SWB 350 700R4 TKO600
Re: EXHAUST 101:
« Reply #3 on: April 09, 2009, 07:43:25 pm »
Muffler installed.  Thanks all for the help.
