Author Topic: 82 chevy c10 dies sometimes at intersections?  (Read 19050 times)
Offline Justinsyrell
« on: April 11, 2009, 07:49:43 pm »
82 chevy c10 dies sometimes at intersections? I need some advice from you all! When the truck is cold if I let off of the gas it will die every time. And when it is cold when I step on the gas to fast it bogs out. And after the truck is warmed up at intersections when I stop it sometimes dies. What do you all think, I just bought it so I do not know when the last tune up was maybe 10 years ago! I was thinking of running some carb cleaner that you put in the gas tank through the truck, do you think this might help, or what do you suggest. Thanks Much, Justin
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: 82 chevy c10 dies sometimes at intersections?
« Reply #1 on: April 11, 2009, 08:26:05 pm »
you don't have a tach do ya--wonder what the idle rpm is
You could have any one of a long list of things wrong....
choke adjustment
air fuel mix wrong
vacuum leak
timing
idle set too low
etc...
Does she run good at high speeds?
Offline Unofficial
« Reply #2 on: April 11, 2009, 08:59:24 pm »
Not to hijack the thread, but my '87 does the same exact thing, except I have TBI. I'm thinking maybe my TBI to intake manifold gasket is bad and it's causing a vacuum leak there.
1987 Custom Deluxe R10
350 TBI bored .040 over
MSD ignition
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
« Reply #3 on: April 11, 2009, 09:04:14 pm »
if your tbi does that, it is the idle air control valve  that keeps the tbi working w/ a specific amt of gas/air.
see:
http://forum.73-87chevytrucks.com/smforum/index.php?topic=5645.0
Offline gold84gmc
« Reply #4 on: April 13, 2009, 09:07:32 pm »
my truck used to act similar....the cause ended up being a clogged fuel filter...so i would check that and if its dirty then replace it and see what happens
92 buick century custom 3.3L
Offline Unofficial
« Reply #5 on: April 14, 2009, 01:27:54 pm »
I posted in your thread the same way I did in this one. I changed my fuel filter, didn't make a difference.
MSD ignition
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
« Reply #6 on: April 14, 2009, 01:51:19 pm »
Unofficial, you mention you think the idling problem may be the gasket for the Throttle body.  There is an easy test to see if air is getting under there, and that is the good ole WD40 spray trick.  Spray some WD40 around the base when your truck is idling, if the rpms shoot up, you found a vacuum leak.
But, I believe the idle air control valve and computer would compensate for that to some degree, therefore, I beleive what I posted earlier about the idle air control valve
« Reply #7 on: April 15, 2009, 12:50:06 am »
I think I will replace the fuel filter first and do a complete tune up on the truck and see if that helps. The engine runs good when it is not at idle, not only does it run good it sounds good, just dieing at intersections. I must push on the gas just a little at intersections to keep the truck running, thats how I am driving the truck for now. And it does seem to idle low, how do I adjust the idle, is it just a screw? Thanks Much, Justin
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
« Reply #8 on: April 15, 2009, 07:15:50 am »
you should have a screw  on the lever where your accelerator linkage meets the lever/carb.  YOu'll see a spring too to keep the lever down unless pushing on it with your foot.  Anyway, there is a screw on that lever that you can adjust so that the lever doesn't go down all the way, the more turns you put in it, changes how low (or not so low) the lever goes back.
You probably have a vacuum leak.  Take some WD40 and spray around hoses and such, gaskets, etc. and see if idle increases.
Offline Unofficial
« Reply #9 on: April 15, 2009, 09:12:36 am »
I would try that, but my parents took my truck away and I probably won't be seeing it anytime soon, if ever again. Thanks for the suggestion though, I'll try it if I get it back.
MSD ignition
Offline ccz145a
« Reply #10 on: April 15, 2009, 10:18:00 am »
Grades come in?
Offline Unofficial
« Reply #11 on: April 15, 2009, 12:20:56 pm »
Grades come in?
Haha, I actually get good grades. I got pulled over.
MSD ignition
Offline eventhorizon66
« Reply #12 on: April 15, 2009, 12:24:08 pm »
Always keep a box of fresh doughnuts in the truck for a roadside bribe. :D
'85 C10 SWB 350 700R4 TKO600
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
« Reply #13 on: April 15, 2009, 01:25:29 pm »
Quote
I heard that....I mean read that.
 ;D
It'll work for me, but they must be fresh.
Offline Unofficial
« Reply #14 on: April 15, 2009, 01:28:42 pm »
It was the State Patrol  :o
MSD ignition
