Author Topic: Big Block Conversion - 1975 Jimmy  (Read 16094 times)
Re: Big Block Conversion - 1975 Jimmy
« Reply #15 on: April 12, 2009, 05:18:25 pm »
The dynomax headers are good but you may need to double gasket or run thicker gaskets at the heads. I always run the thick ones. The ceramic coat doesn't last very long.
Offline Stewart G Griffin
« Reply #16 on: April 13, 2009, 10:50:37 am »
So anyways, back to SBC to BBC conversions:
1) If stock manifolds are used (and i now know that they aren't in this particular case) will they (the BB's) bolt right up to the stock SB exhaust system?
« Reply #17 on: April 13, 2009, 11:18:56 am »
1) If stock manifolds are used will they (the BB's) bolt right up to the stock SB exhaust system?
No.
