Body, Glass & Paint
Hoods
Topic: Hoods (Read 60498 times)
HAULIN IT
Re: Hoods
Reply #15 on:
April 28, 2009, 05:04:56 pm »
Chris, Isn't there something with the latch/safety catch also that changed in '79 also? Now I can't think how it is...do you need to change the latch to match the hood if you change over to the "new" style or vice versa? Lorne
Re: Hoods
Reply #16 on:
April 28, 2009, 08:19:28 pm »
Do you mean the inner hood release? That was an option but the hood was the same. The latches were different.
HAULIN IT
Re: Hoods
Reply #17 on:
April 29, 2009, 11:14:13 am »
Vile, I was referring to the '79-'80 hoods bolt-on striker pin on the underside. The older ones had a pin & the newer had a loop type, Right? Does the plate that bolts on the hood with this pin, bolt on in the same way? I have done this before, but it's been years! It seems to me I remember changing the top piece on the rad support? I guess what I'm saying/asking is...If you had a "basket case" '77 truck without a hood, but had the rad support & you went to the junkyard & got a '80 hood...you would have to go back & get either a older striker (if it bolts on) or the latch from the '79-'80 before you could latch your hood, Right? Or is my memory fadding? Thanks, Lorne
exilous
Re: Hoods
Reply #18 on:
April 29, 2009, 07:24:20 pm »
my 78 has that big loop thing for a latch no pin.
Re: Hoods
Reply #19 on:
April 29, 2009, 08:36:09 pm »
Hood latches are broken down like this
73-74 (this has the release in the middle)
these are the one that are offset
75-76
77-80
This is a completely different setup.
81-87(91)
Last Edit: April 30, 2009, 04:22:55 pm by Captkaos
choptop
Extended cab fanatic
Re: Hoods
Reply #20 on:
April 29, 2009, 10:00:52 pm »
I have a question, if I remember right, my 79 has the hood release from insde the truck. Since Im stripping it out, could I save these peices and put it on an earlier truck that didnt have the internal release? Thats the only thing I dont like about the earlier trucks.
HAULIN IT
Re: Hoods
Reply #21 on:
April 30, 2009, 12:44:30 pm »
Ok...We're getting somewhere. Now does all of the latch striker plates under the hood bolt on the same '73-'80 (4 bolts that tread into the bottom of the hood) which makes any hood fit any truck (as long as you have a matching latch) on the bottom to go with the top? What is with the "off-set" one? Is this what makes me think I changed the top rad support piece once, I just didn't have the right upper piece? Thanks, Lorne
Re: Hoods
Reply #22 on:
April 30, 2009, 04:21:35 pm »
ok, that was a typo on the offset, all of the 75-80's are offset 73-74's were the ones with the latch handle in the center...
1977 was the first year for the underhood latch release. The latch can be used on any 77-80.
bigkountry
Re: Hoods
Reply #23 on:
May 04, 2009, 01:39:57 pm »
I'm kind of partial to the reflexxion dual cowl, looks like the one I had on my 01 Silverado.
CA Big Red
Re: Hoods
Reply #24 on:
January 18, 2014, 08:47:27 pm »
My 78 didn't have the lip, but the hood I just bought from a '73 does. I ran into a gal that had an original '75 with no lip. So, what's with the lip? What years or trim models came with the lip on the front?
Sent from my iPad using
Tapatalk
"You don't know what you don't know."
1978 Scottsdale Stepside
383 w/ 4" lift & 35" BFG
Re: Hoods
Reply #25 on:
January 18, 2014, 08:56:02 pm »
I posted this in your other thread... but no 75 came with the lip on the front, nor did the 73. That was 79-80 ONLY.
dvdswan
Re: Hoods
Reply #26 on:
January 18, 2014, 09:49:52 pm »
I'm not seeing this lip on the 79-80 hood as compared to the 73-78 hood. the hoods look similar. aside from the hood ornament which I would like to find because I think mine came with one as there are holes in the hood where a ornament would be... I think. on my 76 Blazer I had a fiberglass hood that stepped down, I will see if I can dig up a picture.
Quote from: hotrod24 on April 13, 2009, 07:51:36 pm
vile here is my 73-78 stock hood
Dave
78 K10 Stepside
http://s36.photobucket.com/user/dvdswan/story/10553#
Re: Hoods
Reply #27 on:
January 18, 2014, 11:16:07 pm »
Re: Hoods
Reply #28 on:
January 18, 2014, 11:21:31 pm »
someone on here has a chrome trim piece just on that lip.
CA Big Red
Re: Hoods
Reply #29 on:
January 18, 2014, 11:36:48 pm »
Thanks Captkaos, I'm clear now. I just bought a 79-80 then.
Thanks for clarifying.
Tapatalk
Body, Glass & Paint
Hoods
