Author Topic: horn will not work  (Read 5567 times)
Offline necromonger
horn will not work
« on: April 17, 2009, 12:54:03 pm »
Ok good relay no blown fuse i am at a total loss.
new build,1978 chevy 3/4 ton 2 wheel drive 350 4 speed trans.
Offline hotrod24
Re: horn will not work
« Reply #1 on: April 17, 2009, 01:29:18 pm »
do you have all the horn contacts? and do you have everything wired up right?
1978 pontiac grand prix...
Offline necromonger
« Reply #2 on: April 17, 2009, 05:42:55 pm »
yes i do.
Offline hotrod24
« Reply #3 on: April 17, 2009, 05:44:37 pm »
have you checked to see if your horn works? by grounding it to the body
Offline necromonger
« Reply #4 on: April 17, 2009, 06:10:53 pm »
I'll try that next
Offline hotrod24
« Reply #5 on: April 17, 2009, 06:22:06 pm »
yea i would try that because when i got my truck and i started working on the horns one worked and the other did not but a little after that it stoped working to so it does not take much but anyway watch out for your ears lol
« Last Edit: April 17, 2009, 06:25:42 pm by hotrod24 »
