Author Topic: wiring to 700r4 trans.  (Read 3607 times)
Offline shortchevy84
« on: April 27, 2009, 11:23:00 am »
hi, my 86 short box had a 350c trans in it as far as i can tell, as it had the lock up converter plug. anyway, i am putting in a built up 700r4 and i purchased the wiring harness that has 3 wires into the 4 wire end. the colors are green blue orange on the wiring in the truck, but has melted connecter that i am replacing. however the new harness has green/white, orange/black, and purple. should i just allign where each wire went in the harness? however, the old harness is melted so i can't be 100% sure which way the connector faces, so scratch that idea. basically i need a wiring diagram from a 700r4 trans and one from a 350c so i know which wires to connect. thanks.
