73-87 Chevy & GMC Trucks
1983 3/4 ton truck.....What should I do?
Topic: 1983 3/4 ton truck.....What should I do? (Read 4585 times)
grinder1989
May 09, 2009, 07:27:20 pm »
The truck has a 14 bolt, 700r4 tranny, and a 305. Should I take the suspension and rear end out and swap it with mine? The truck is going to be a winter beater, I don't care what happens to it. The 83 is a long bed and my 74 is a short bed 1/2 ton.
Sundown Authorized Dealer, Akron OH
choptop
Extended cab fanatic
Re: 1983 3/4 ton truck.....What should I do?
May 09, 2009, 07:29:58 pm »
Hmmmm. A shortbed 3/4 ton. Might look pretty cool even if it is a beater. Question is, do you need the heavier suspension components?
grinder1989
May 09, 2009, 07:38:12 pm »
No the 83 will be the beater, my 74 is going to slowly be restored and ran at the track quite a bit. I figured the 14 bolt would be useful once I got the big block put in.
choptop
May 09, 2009, 08:10:26 pm »
I think the weight would offset the benefit. Many are running to 10 bolt with no problems.
grinder1989
May 09, 2009, 08:12:41 pm »
Indeed but I have a 12 bolt and it's not a posi
But either way, for $425, it's still a good buy.
