Author Topic: Dually  (Read 4770 times)
Offline BigStella
Dually
« on: May 22, 2009, 07:56:39 am »
I have a Chevy Dually I am working on.  It is a 1977 but I have replaced the bed with a 1985.  I need the passenger side dually fender.  Does anyone know where I can find one of these?  It seems everyone local wants me to buy the entire bed, and all I need is one dually fender...
Any help is appreciated.
Offline 80stepsideguy
Re: Dually
« Reply #1 on: May 22, 2009, 11:15:02 am »
Do you happen to have the original one from the 85 bed? If so with a little work it can be redone and if you take your time you can make  it look like it was never repaired.
Or try looking at :
www.usbody.com
thanks
pat
1998 Chevy 1500 S/B 2wd
Offline BigStella
Re: Dually
« Reply #2 on: May 22, 2009, 11:18:41 am »
I do have original.  It has quite a few cracks in it.  I have never worked with fiberglass before is the problem.  Is it pretty easy?  What are the steps to fixing it?
Thanks
Offline HAULIN IT
Re: Dually
« Reply #3 on: May 22, 2009, 01:43:25 pm »
Post up a couple pictures so we can give you the best advice. Top side & bottom. Maybe number the areas in some way so we can refer to them individually. Lorne
Offline cubicdollars
Re: Dually
« Reply #4 on: May 22, 2009, 09:33:34 pm »
A local body shop ordered one for me it was a couple hundred bucks
Re: Dually
« Reply #5 on: May 26, 2009, 05:03:52 pm »
this has been posted alot, but http://www.hannemannfiberglass.com/ has them.
