Author Topic: TBI manifold and cam  (Read 12387 times)
Re: TBI manifold and cam
« Reply #15 on: May 27, 2009, 05:12:27 am »
You can use that intake on your existing heads you'll just need to elongate the 4 center holes in the intake. Everything else will bolt up. If you wanted to run TBI you'd have to put an adapter plate on it.
Offline 87GMC2WD
« Reply #16 on: May 27, 2009, 05:59:54 am »
ok thank you. im on the right track now and sorry for the cofusion. i will probably try and sell mine then and get the 2104. I would have to do some grinding on a brand new manifold to get that 2101 to fit. but thank all you guys for your help. I use that summit K1102 cam and try a 2104 manifold.
