Author Topic: rear post interior panel  (Read 9637 times)
Offline casey
« on: May 28, 2009, 07:44:14 pm »
I've restored an 83 reg cab. chose to do black interior and had to dye a few parts. I dyed the rear post panels where the seat belts bolt into and find they are scratching easily, does anyone know where to get aftermarket panels?   does not offer these.
Online Captkaos
Re: rear post interior panel
« Reply #1 on: May 29, 2009, 01:31:19 pm »
how did you prep them?  Your a going to be much happier with factor plastic.
Offline GoatBeard
« Reply #2 on: May 31, 2009, 11:42:23 am »
One thing that I thought about was after painting/dying the panels the color you want come back with a flat clear coat.  I think this would solve your problem -- especially on panels that you can't help but to touch somehow.
Offline robzkool2
« Reply #3 on: June 02, 2009, 11:25:07 pm »
an old paint dude told me to try denatured alcohol after you wash & dry the plastic or vinyl.there's something about the alcohol that makes the part seem sorta sticky.it iz an excellent adhesion promoter to the dye.especially on 22 yr old parts.
keep 'em shiny side up!
87 GMC Sierra half ton driver
79 Chevy El Camino project
Offline HAULIN IT
« Reply #4 on: June 03, 2009, 05:11:49 pm »
Casey, Welcome to the site! Most interior trim that has been properly painted ("dyed") lasts very well, even armrests, ect. with casual use. The panels you are referring to, I wouldn't expect any problems with for sure. One thing that comes to mind on your panels, is the felt or plastic washer behind the pivot part, do you have one? This could/would help allot. Lorne
Offline GoatBeard
« Reply #5 on: June 08, 2009, 12:13:44 pm »
I have been using the stuff Duplicolor sells (I think it's called Grease and Wax Remover).  After that you spray on some Adhesion Promoter.  I've noticed that after I wipe everything down with the Grease & Wax stuff I actually get some static from the parts.
Offline treepete
« Reply #6 on: June 08, 2009, 05:50:08 pm »
Im on the search for these rear pillars as well.  Chris, if you see some, snaggle them up for me.
1983 Silverado
1999 Yukon Denali
Other problem: Off-Road R/C.     www.rccorral.com
Offline GoatBeard
« Reply #7 on: June 09, 2009, 07:12:56 am »
Will the rear pillars out of a K5 work on a truck?
Offline treepete
« Reply #8 on: June 09, 2009, 10:20:53 am »
that I defer to someone who is in the know.
1983 Silverado
1999 Yukon Denali
Online Captkaos
« Reply #9 on: June 09, 2009, 11:24:08 pm »
No, blazer pillars and pickups are different.  Blazers are unique to themselves.
Pickups are the same as far as the rear go including crew cabs...
Offline GoatBeard
« Reply #10 on: June 11, 2009, 03:49:40 pm »
Well, if you want to try to figure out how to retrofit them, I can get you some off a K5.  ;)
I'll keep my eyes open.
