Author Topic: Door skin, door handle support question  (Read 5679 times)
Offline 80stepsideguy
« on: June 02, 2009, 03:02:12 am »
Question,
i`m going to replace my drivers door skin shortly with a NOS 1 i got i bought quite a while back. The NOS door skin didnt come with the inner door handle support. I luckily bought 1 off of ebay and now i`m about to remove the old skin,but before i install the new skin the door handle support needs to go in.Did they come factory welded on the skins or were they bonded with a epoxy to the skin???
thanks
pat
1998 Chevy 1500 S/B 2wd
Offline HAULIN IT
Re: Door skin, door handle support question
« Reply #1 on: June 02, 2009, 09:09:49 am »
Pat, They were spotwelded originally & the handle (mostly) hides the spotwelds. For the new one, I would use an adhesive. Unless you have a high quality spot welder, anything else will lead to a large heat zone. Just my thoughts, Lorne
« Reply #2 on: June 02, 2009, 11:06:08 am »
I was thinking like clean a spot on the support and use JB WELD that way its on there for good.I appreciate the input but i dont got a spot welder that`ll get that clean of a weld so looks like JB weld will work...
thanks
pat
Offline hotrod24
« Reply #3 on: June 02, 2009, 11:47:26 am »
pat you could get this if you have the right welder
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=98759
1978 pontiac grand prix...
« Reply #4 on: June 02, 2009, 01:53:59 pm »
Nope i`m gonna jb weld it
I dont need a tool that i`m only gonna use once and then collect dust.. Rather JB weld it and be done with it..
thanks
pat
« Reply #5 on: June 02, 2009, 09:20:15 pm »
I would use a panel adhesive over JB Weld. Grind the two parts to be glued together for a mechanical bond. Then Use 3M's or Fusor's panel adhesive. Clamp it with a couple clamps.
« Reply #6 on: June 03, 2009, 02:26:53 am »
Thanks blazin
I`ll see bout getting it from my paint supply store.I got the gun for it so i`m good there..
thanks
pat
