Author Topic: Transmission and rearend identification and verification  (Read 5684 times)
Offline trem0r
  • Information Technology Engineer
« on: June 02, 2009, 10:16:38 am »
This is from the underside of my newly aquired project truck.  82 swb.
I'm pretty sure that this is a th350 and a 10bolt, can someone please verify?
Offline trem0r
Re: Transmission and rearend identification and verification
« Reply #1 on: June 02, 2009, 10:17:05 am »
And here is the rearend:
Offline 4x4orbust
« Reply #2 on: June 02, 2009, 10:54:50 am »
you are correct sir.
Offline trem0r
« Reply #3 on: June 02, 2009, 10:58:02 am »
Sweet deal.  Thank you so much!
Any idea on how to identify what kind of gearing the 10 bolt has in it?
« Reply #4 on: June 02, 2009, 06:38:54 pm »
pull the cover off and read the numbers on it and divide.
Offline 4x4orbust
« Reply #5 on: June 02, 2009, 07:12:14 pm »
not sure if you have the RPO codes in your glovebox, they will tell you gear ratio. my 82 has 3.08, others have 3.42 (i believe).   another way to tell is to mark your driveshaft, then turn the wheel one full rotation while counting the driveshaft rotations.  the ammount your driveshaft turns is approximate gear ratio.  to know for sure what you have, you have to pull the cover and count.
Offline trem0r
« Reply #6 on: June 03, 2009, 12:30:03 am »
Cool.  Thanks guys
