Author Topic: Need help with clutch pedal  (Read 3584 times)
Offline crobey4393
« on: June 04, 2009, 03:50:55 am »
I have a 77 C/10 with manual clutch. I need to change it over to a hyd clutch. I am in need of some help with mounting the Master Cyl.and hooking up the pedal assy.
Any pics of M/C Mounting or pedal modifications is appreciated.
Yhanks
Chuck
1977 Chevy C/10 Installed a Cummins 3.9 4BT w/NP-435
Re: Need help with clutch pedal
« Reply #1 on: June 04, 2009, 06:10:06 am »
The hanger is the same. Best bet is to get the pedal and rod from a truck with a juice clutch, and swap it into place. As far as mounting it just messure the parts truck while you are robbing the pedal, then mount the master in the same spot.
