Author Topic: fit a 77 K20?  (Read 4840 times)
Offline pacu44
fit a 77 K20?
« on: June 18, 2009, 10:04:12 pm »
Will this fit a 77 K20?
U.S. Wheel 84-7080 - U.S. Wheel 84 Series Black Daytona Wheels
Compare  Wheel, Daytona, Steel, Black, 16 in. x 10 in., 8 x 6.5 in. Bolt Circle, 4.125 in. Backspace, Each
Part Number: USW-84-7080
or this one?
U.S. Wheel 84-8980 - U.S. Wheel 84 Series Black Daytona Wheels
Compare  Wheel, Daytona, Steel, Black, 17 in. x 9 in., 8 x 6.5 in. Bolt Circle, 5 in. Backspace, Each
Part Number: USW-84-8980
thanks in advance
Offline 79K20
Re: fit a 77 K20?
« Reply #1 on: June 19, 2009, 10:23:57 am »
Those 17's will likely rub. That's a lot of backspacing, intended for later-model trucks. I think 4.5-ish B.S. is about all you can do without hitting tie rod ends on the older Chevys. If you're stuck on 17's, try the 84-8880 instead. Same wheel but with a 1/2-inch less BS. (17x8, 8 on 6.5", 4.5 BS)
The 16's will fit fine. And the tires will be cheaper, too.
