Author Topic: How to Remove Window Scraper  (Read 10781 times)
Offline treepete
« on: June 21, 2009, 12:47:20 pm »
Hey guys, happy fathers day.
Umm I got some new outer window scrapers for my 83. Im wondering the best  method to remove the originals. On the new ones, all i see is a small metal clip every 8 inches or so, and they look to press straight in from above ( the same way the window travels.)
I cant get the old ones out. I dont mind if the originals get ruined, cause they are all peels and crumbly anyway.. can I just muscle them out?
thanks in advance for your thoughts on this.
Pete
1983 Silverado
1999 Yukon Denali
Other problem: Off-Road R/C.     www.rccorral.com
Offline Skunksmash
Re: How to Remove Window Scraper
« Reply #1 on: June 21, 2009, 06:00:36 pm »
Not sure what you mean by scrapers. Do you mean windshield wipers? If so it's just a little pin that you take out where the arm meets the wiper.
Offline low budget
« Reply #2 on: June 21, 2009, 10:14:15 pm »
They are a bear to get off sometimes, but just keep working with it.  You might bend the old one's up, but you said you didn't care.  The clips hold pretty tight...
Offline treepete
« Reply #3 on: June 22, 2009, 09:43:31 am »
window scraper for me is the felt part on the door, where the window dissappears into the door. Mine are gone, and if I were to take the truck outside or something, and it rained, the rain would run down the window and inside the door. not that I would take it outside or anything though. :)
So yeah. I think Ill just try to pull on it with something. I just dont want to mar the paint.
thanks for the advice.
1983 Silverado
1999 Yukon Denali
« Reply #4 on: June 22, 2009, 03:56:16 pm »
Roll the window down and grab ahold of it and pull it up rolling it a little towards you.  The  clip on themselves through the hole.
Offline ccz145a
« Reply #5 on: June 22, 2009, 04:36:13 pm »
You're standing inside the door when you do this. Each clip has a little hole, work them off one by one.
Offline treepete
« Reply #6 on: June 23, 2009, 09:36:05 am »
ok guys, thanks for the replies. Ill try that when I get home today. I have been approaching it from outside the truck. I think Ill stand inside the door and see if that works.
Pete
1983 Silverado
1999 Yukon Denali
Offline ccz145a
« Reply #7 on: June 23, 2009, 10:35:58 am »
You can stand either side... was just clarifiying what "towards you" meant. Outside will be "away from you".
Offline treepete
« Reply #8 on: June 24, 2009, 08:34:12 am »
ok i figured it out. for me, the easiest way to get this clip off was to use a linoleum knife. its hooked in such a way that you can get under the clip and pull upward until it breaks free, and thin enough to get down into the door like a slim-jim.
so yeah, it mangled the stock pieces but they came out without a struggle.
the new scrapers went in easy and fit awesome. good as new,
 thanks for the help guys.
Pete
1983 Silverado
1999 Yukon Denali
Offline ccz145a
« Reply #9 on: June 24, 2009, 09:51:24 am »
Good deal!
Offline The dream
« Reply #10 on: June 24, 2009, 06:17:27 pm »
were did you buy does scrapers?
Never give up.
Offline treepete
« Reply #11 on: June 30, 2009, 08:21:24 am »
I got those from CI.
1983 Silverado
1999 Yukon Denali
