Author Topic: non ac to ac  (Read 4595 times)
Offline 2502
non ac to ac
« on: June 24, 2009, 08:05:07 am »
does anyone have pics or directions etc wiring up the fuse block? i got it all mocked up but wiring is something i stay FAR away from. looks to be just the wiring for the controls tap into an existing slot for the ac to run and then it just keeps splittiong off as it goes. i already have the wiring harness but i suck at wiring so i wanna be sure i don't get a loose connection later. dummy proof instructions if anyone has em would be grrrrrrrrrrrrrrrrrrrrreat.
Re: non ac to ac
« Reply #1 on: June 24, 2009, 04:36:24 pm »
have you looked in the tech section?  I posted all the wiring setups here, and Vile has posted numerous AC wiring schematics
Offline Skunksmash
Re: non ac to ac
« Reply #2 on: June 25, 2009, 09:02:18 am »
Ever taken a look at that company called vintage air? Had a friend that used to install their stuff sometimes. They might have a whole kit for you.
Offline 2502
Re: non ac to ac
« Reply #3 on: July 22, 2009, 02:39:12 pm »
i actually used their tech instructions to get my stuff swapped over. i was trying to just stick with factory since i already had all the parts from another truck to swap right over...
