Author Topic: Which crate to go with?  (Read 26323 times)
Offline chevymotocross
« on: June 25, 2009, 03:40:09 pm »
Will soon be finishing up the body work on my 87 truck. I want to eventually drop a fresh crate engine once money builds up again. Currently, the truck sports a stock 305 with some bolt ons (bumped up fuel pressure, tbi spacer, injector spacer, dual exhaust). Healthy 700r4. The engine runs well but it does have quite a few miles on it, smokes on startup as well. Plus.... the 305 is a slug.
I was checking out the GM Performance crate engines. The warranty they come with are awesome. I am thinking to either upgrade to the stock L05 350 truck engine or few just a few hundred more, upgrade to a 1996+ style 350 with vortec heads and roller cam.
I am sure either engine I go with will offer more performance than my 305. Which should I go with? I want to keep the TBI and get decent mileage with some power to play with as well. I know the L05 has the same crappy swirl port heads like my 305 and the whimpy flat tappet cam.
How well are the vortec 350's in stock form? Is the stock cam decent? Is it night and day compared to the L05? I know I well have to buy a TBI to vortec manifold which is like $400. What else would need to be done (besides a chip upgrade of course)?
Oh, I have thought about a 383, but they are more in the $3500 range...... I don't want to spend that much.
1987 Chevy Silverado 2wd SWB: 305 TBI, 700r4, dual exhaust, tbi mods, k&n filter, belltech sway bar
Offline eventhorizon66
Re: Which crate to go with?
« Reply #1 on: June 25, 2009, 04:42:57 pm »
Between those two motors, I would favor the L31.  You'd be getting the best production Gen1 heads chevy ever made and a roller cam.
Have you also considered picking up a used LM7 5.3L engine?  It will be more involved, but my guess is you will be happier with the end result.  Around here you can pick up a <50K mi 5.3L for $750-900.  From there you have the option of upgrading to a 4L60E, 4L65E, 4L80E, or just keeping your 700R4.  If I could go back in time, before I swapped my 305 for a Goodwrench 350, this is what I would do.
« Last Edit: June 25, 2009, 05:12:47 pm by eventhorizon66 »
'85 C10 SWB 350 700R4 TKO600
« Reply #2 on: June 25, 2009, 05:03:18 pm »
Have you also considered picking up a used LM7 5.3L engine?  It will be more involved, but my guess is you will be happier with the end result.  Around here you can pick up a <50K mi 5.3L for $750-900.  From there you have the option of upgrading to a 4L60E, 4L65E, 4L80E, or just keeping you 700R4.  If I could go back in time, before I swapped my 305 for a Goodwrench 350, this is what I would do.
I have considered this. I have also had the opportunity to purchase TPI engines with complete harnesses. Thing is, I really don't want to get that involved, I basically want to just swap engines, minor tweaking if necessary, and be done with it. I give respect to those who have done those types of swaps, but it is something I don't think I would want to tackle.
Offline 07montecarlo
« Reply #3 on: June 27, 2009, 07:10:27 pm »
if me i would go carb/hei, dont get much more reliable than that!!!!! k.i.s.s...if you do shopping and do the work yourself you could have a good reliable 350 for 2000-3000 bux..but you'll have to build yourself. which is not hard with the right tools..read and research you could get a smogged out 350 change pistons for higher compression and some minor port work
decent cam and utilize your current pulleys brackets..good free flowing exhaust and carburation will net you a good solid 350 horse small block that you can get in and drive normal or have a little throttle on tap if needed...
« Reply #4 on: June 27, 2009, 11:08:04 pm »
Although going carb would probably allow making more power easier and probably cheaper than TBI.... I want to stick with the TBI system.
Offline Jims86tpisub
« Reply #5 on: July 15, 2009, 03:34:21 pm »
I would go with the L31 vortec, get the required intake manifold and Chip, plumb the EGR from the exhaust manifold, and be done with it.
Jim
1986 K10 Suburban
Tuned Port Injection
193 Heads
Comp 260H cam
700r4 Raptor
Single exhaust with 2 Magnaflow Mufflers inline
Offline SUX2BU99
« Reply #6 on: July 16, 2009, 01:07:13 am »
Event, I'm curious as to why you chose going for a 260 HP 350 crate and not instead step to at least the 330-horse Vortec-head motor. Was it cost?
« Reply #7 on: July 16, 2009, 11:48:00 am »
I'm curious too.  Brain fart, I guess.  But yes cost was a factor.  Unfortunately, now I'm in a position where I want a set of Vortec heads and a larger cam, if I keep this gen 1 SBC >:(.  Otherwise, I'll do what I suggested above and swap in a gen 3.  Fortunately, a complete lack of excess funds gives me some time to think about it, LOL.
Offline fitz
« Reply #8 on: July 16, 2009, 06:48:58 pm »
Captkaos has a link to the Car Craft article where they modified the 260 HP crate motor. You could start off with the 260HP and modify it when the budget allows you to.
« Reply #9 on: July 16, 2009, 08:03:54 pm »
I know.  It's actually Chevy High Performance that did the series "The Goodwrench Quest."  I even have all the physical copies of these articles buried in a box somewhere.  It's something along the lines of part 5 I would shoot towards, if I end up keeping the Gen 1 engine.
Offline bigblue09
« Reply #10 on: July 17, 2009, 12:04:13 am »
i found a 350 short lock on ebay for like 2500 maybe a little less. its for pre 88 trucks with tbi. its 300-320 hp.
'87 Silverado EFI 305
Offline fitz
« Reply #11 on: July 17, 2009, 05:37:51 pm »
 How are the emissions testing in CT ?. Can you get away with running a carb on your 87. In Ma the just changed the laws so that anything 1995 or older just needs the safety inspection, they don't check the emissions.
 I know most people now want to run FI but I still think that a carb is the cheap way to make power.
Offline Chevalade
« Reply #12 on: July 22, 2009, 07:33:36 am »
Jeeze, get a used caddy motor out of a 68-76 eldo, $5-600, BOP style turbo 400 - $500, swap out valve springs and put a new timing chain on it, and have more tq and hp than most crate engines for less than $1500....weighs about the same as the small block too.
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #13 on: July 22, 2009, 08:52:26 am »
Offline TexasRed
« Reply #14 on: July 23, 2009, 10:13:41 pm »
I see no mention of a flexplate included in the deal. I thought the balanced rotating assembly had to have that as well? I also doubt the smooth idle with that much lift. I also don't see a dyno chart showing the actual output. All that said, that's not really a bad price for something you put an intake, carb, distributor, and a few other little things on and fire up.
