Author Topic: Help... Ugh.... Torgue Coverter won't slide forward towards the flexplate?  (Read 17382 times)
Offline HAULIN IT
Mike, Once you sanded it a bit, where you able to spin the converter with the bell housing bolts tightened down. This is a simple thing to check that is sometimes overlooked & tells you if the converter is properly seated. Lorne
Offline Mike Phillips
Yes.
I've reinstalled the transmission and transfercase and torqued everything down.  Everything appears to be fine now.
Moving on to oil pressure line, tranny lines, drivelines, shift linkage for tranny and tcase, etc.
Here's the list as of yesterday, the torque converter issue really slowed me down but that's behind me now.  (As I cross my fingers)
Will update in a few hours as I start bolting more things on.
Offline HAULIN IT
Looks like you should be working on the boat...the list is MUCH shorter to be completed  ;D
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
You forgot a few crucial steps that I did when I installed my 383 stroker in my truck....
Perhaps that is why I had trouble mounting my flex plate to the harmonic balancer  ;D
Offline DnStClr
LOL
Don
87 Chevy Silverado
Offline ccz145a
ROFL. That there is funny.
