Author Topic: Heat up issue.  (Read 4838 times)
Offline 87OldYeller
Heat up issue.
« on: June 28, 2009, 12:22:47 pm »
Problem I am having with my truck, it runs great but once it gets up to normal temp after driving I shut it down and the temp, climbs to almost 240 Deg. Upon restart the temp drops back to noraml at about 210. I am running manual fan, I am thinking about going to electric. But any ideas on the heating issue? I am about to install all new guages. I am thinking about a lower temp thermostat to.
Re: Heat up issue.
« Reply #1 on: June 28, 2009, 12:33:38 pm »
That rise in temp is normal when you shut the engine down.  Mine runs lower, around 180 in my 85 but how accurate is the OEM stock gauge that is 24 years old?
Offline 87OldYeller
Re: Heat up issue.
« Reply #2 on: June 28, 2009, 12:40:51 pm »
it is an aftermarket guage.. but ok .. i think i am just gonna run a 160 deg tem. thermostat.
Re: Heat up issue.
« Reply #3 on: June 28, 2009, 12:45:12 pm »
Assuming that you have a TBI being a 1987??? I would go with what is called for.
Re: Heat up issue.
« Reply #4 on: June 28, 2009, 11:52:01 pm »
keep the 190 in there you will miss it in the winter lol but 240 ain't too bad if it is make sure you have a mix of 50/50 to much antifreeze will cause you to run hotter and increase your boiling point temp. too much water will decrease you boiling point causing you to boiling over when its not needed but you will run cooler but at the same time just running water ain't going to boil unless you reach waters boiling temp that is 212, but thats where the rad cap comes into play keeping water at a higher pressure will keep the boiling point higher.
« Last Edit: June 28, 2009, 11:54:53 pm by Irish_Alley »
Offline Skunksmash
Re: Heat up issue.
« Reply #5 on: June 29, 2009, 08:58:10 am »
My TBI truck's heat gauge says that 220 is too hot. Oddly enough though, my truck never gets above what i would seem to be about 155 degrees. Strange. I have never had one of these that ran below 180. But they were all carb'd. And i know the heat gauge works fine cause one of the first things i had to do when i bought the truck was get it working with a new sensor and a new wire. Might be something to think about since we likely have the same engine.
Re: Heat up issue.
« Reply #6 on: June 29, 2009, 10:31:52 am »
TBI motors call for a 195 Stat.  I would keep it that way.
Offline 87OldYeller
Re: Heat up issue.
« Reply #7 on: July 09, 2009, 07:22:58 pm »
After the install of my Dakota Digital Guages i noticed that the temp is fine. Guess it was a bad guage.. thanks for the help though.
