Author Topic: Engine Accessory Drive  (Read 6181 times)
Offline 81Cheyenne
« on: June 30, 2009, 08:34:40 am »
I'm building a 1982 K-24 Camper special.  I bought the truck without an engine so I got a vortec long block crate engine to drop in it.  I also ebay'ed a complete serpentine setup with AC compressor on the driver side but I'm having second thoughts on using it. Running into a lot of headaches matching the newer accessories (alt,AC,hoses...etc) with existing condensor,wiring and so forth. I'm thinking of just selling the serpentine and piecing together a v-belt setup. Anybody care to share any experience with dropping a new setup in an older truck?
Re: Engine Accessory Drive
« Reply #1 on: June 30, 2009, 02:51:44 pm »
The serp setup is worth changing a little wiring and some hoses in my opinion.  I just picked one up for a BBC.
Offline ccz145a
« Reply #2 on: June 30, 2009, 03:04:00 pm »
Capt, may I ask where?
Offline 81Cheyenne
« Reply #3 on: June 30, 2009, 03:19:32 pm »
Ok, so where do I get a hose that will fit a 98 compressor and a 82 accumulater? The stock 98 hose has a slightly larger fitting on the accum end and won't fit.  Same deal with the hose that goes from the compressor to the condensor.
Offline 82gmc3/4ton
« Reply #4 on: July 01, 2009, 08:05:42 am »
Do you have the aluminum or steel setup? I did it to my truck with the aluminun one and it looks great. I always hated the v belt squeal and the oem brackets being flimsy but didnt have the funds for a March setup. You will need metric bolts for the alternator and a reverse water pump. I bought all of my accessories off of Ebay for great prices.
« Reply #5 on: July 01, 2009, 03:59:11 pm »
Check a local Hose shop to see if they will make you the fittings you need.
Offline 81Cheyenne
« Reply #6 on: July 02, 2009, 09:00:15 am »
Will the newer compressor work well with the older condensor,evap and accum?
