Author Topic: fuel sending unit wires  (Read 46388 times)
Offline bigkat79
« on: July 01, 2009, 10:49:52 pm »
hey folks, got a quick and easy question. i dropped my tank because my guage reads about 3/4 past full the whole time my truck is on. when the power is off the guage reads full or a little less. what im looking for is pictures of where the pink power wire runs to from the tank. i have what i assume is the ground coming from the sending unit (also not hooked up to anything) but i think i see where that is supposed to go, but the pink power wire is nowhere to be found under there. i looked at the wire bundle to the fuse box and see a pink wire in there but i have no idea where it goes into the cab so i can trace it back towards the tank.
thanks in advance for any help.
Offline DnStClr
Re: fuel sending unit wires
« Reply #1 on: July 02, 2009, 11:45:49 am »
I'm assuming your truck is a 79.The pink wire is the signal wire. It runs from the sending unit at the tank directly to the back of the instrument panel electrical connector. According to Capt. Kaos wiring diagrams found here on this site, the pin is #30. The wiring schematics are found  here- (hope it helps ).
http://forum.73-87chevytrucks.com/smforum/index.php?topic=11766.0
Forgot to add- I think the wire physically runs up the left (Drivers) side of the chassis in a bundle.
« Last Edit: July 02, 2009, 11:52:16 am by DnStClr »
Don
87 Chevy Silverado
Offline frogman68
« Reply #2 on: July 02, 2009, 12:04:13 pm »
Actually the wire goes to wires 7 and 18 (18 if dual tank)
Check the ground (even if it looks good take it off and wire brush it and the frame with some new washers)
Offline DnStClr
« Reply #3 on: July 02, 2009, 12:10:07 pm »
Ditto on the ground wire. They sure cause a lot of faults. I'll recheck myself with the schematic on the pink wire.
Don
87 Chevy Silverado
Offline frogman68
« Reply #4 on: July 02, 2009, 12:13:39 pm »
I just installed the gages in a 84 and found this wire was busted I just ran a new one and a new ground..
Offline DnStClr
« Reply #5 on: July 02, 2009, 12:34:31 pm »
Frogman. did ya have any problems with the tail light?
Don
87 Chevy Silverado
Offline frogman68
« Reply #6 on: July 02, 2009, 12:36:51 pm »
Hehe
At that time there was no wiring harness or tail lights but now that the wiring is done they work fine
Offline bigkat79
« Reply #7 on: July 03, 2009, 12:12:11 pm »
hey all, thanks for the information. i got under the truck and found the bundle of wires BUT there are only 4 wires in the bundle and the diagram shows there are supposed to be 5. anyone want to guess which wire is missing? the pink fuel sender wire! i followed the wires back up under the hood to the junction box (?) by the brake master cylander and there is only 4 wires in the bundle all the way. so i have no fuel sender wire what so ever outside of the cab. i did pull the dash and found where it is supposed to be on the instrument panel wiring and it IS there.
oh and since i forgot to mention it so far, it's a '78 single tank setup
Offline bigkat79
« Reply #8 on: July 03, 2009, 01:22:43 pm »
here are some pictures to reference what im talking about...
the 4 wires that are in the bundle that runs down my frame rail
the "junction box" i was talking about. does anyone know where the pink wire should go in there? and how i would put a new one in?
« Last Edit: July 03, 2009, 01:24:51 pm by bigkat79 »
Offline 123 pugsy
« Reply #9 on: July 03, 2009, 04:46:06 pm »
Check the wires coming thru the tube close to the starter motor.
That's where mine runs back. On the passenger side.
Pugsy
76 C10 LWB
TPI 350
Offline DnStClr
« Reply #10 on: July 03, 2009, 05:01:58 pm »
Keeping in  mind that my truck is an 87, mine (there are 2, a pink and a tan) go back thru the wiring tube on the drivers side. The pink wire goes to the connector in your last photo. It goes thru the 3rd space down on the r/h side of the connector, below the yellow wire. It sounds like the wiring was definitely different on the earlier model trucks since Pugsy's wire goes down the opposite side of the frame.
Don
87 Chevy Silverado
