Author Topic: 4wd to 2wd conversion  (Read 21725 times)
Offline bryan103
« on: July 05, 2009, 12:05:16 am »
I just bought a 82 crew cab short bed and its a 4wd,wanting to change it over to a 2wd.Im going to get a donor truck,was wondering how much work im in for.
Re: 4wd to 2wd conversion
« Reply #1 on: July 05, 2009, 12:21:23 am »
Crew cab as in a 3+3 4 real doors? GM never made a crew cab short bed. The frame has been shortend if it actually a short bed. You will need to shorten the 2 wheel drive frame the same amount. Then its just the labor of swapping the Motor, & body over.
Offline bryan103
« Reply #2 on: July 05, 2009, 09:45:30 am »
Yes,its a 4 door,the frame was shortend,i want to just change the suspension,as in the complete front crossmember,spindle to spindle
« Reply #3 on: July 05, 2009, 11:23:06 am »
It can be done. you will need to take the 4wheel drive motor cross member out. You will also need to swap out the front, &  rear spring hangers / shackles for the rear suspension.
Offline bryan103
« Reply #4 on: July 05, 2009, 02:31:06 pm »
I knew about the rear,i justed wanted to make sure the frames are the same from a 4wd 1/2 ton to a 2wd 1/2 ton
« Reply #5 on: July 06, 2009, 12:47:03 pm »
Crew Cabs were 1ton not halfton, but you can swap out the crossmember from a 1/2T 2wd to make it a 4x2.  It is a major undertaking.
Offline bryan103
« Reply #6 on: July 06, 2009, 07:01:12 pm »
I dont think its the factory frame for the cab,it has six lugs and it from a 76 truck
Offline andrewmp6
« Reply #7 on: July 08, 2009, 04:09:55 am »
If i remember right the floor pans are different too the 4x4 has a bigger hump in it.
« Reply #8 on: July 08, 2009, 04:37:55 pm »
Floor pans are the same, only the actual tunnel is different which includes the rear portion under the seat on 4x4's.
Offline 1980c10
« Reply #9 on: August 05, 2009, 09:57:35 pm »
4wd has leaf springs and 2wd has coil springs. I would imagine it is a good ampount of work and i would take pictures before disassebly  to help remmeber where and how everything is set up.
Offline 79K20
« Reply #10 on: August 06, 2009, 02:28:08 pm »
Seems like a lot of work to me....
Why don't you just buy a 2wd 3+3 and then shorten the bed? Seems that would be easier than attempting the 4wd to 2wd swap. C30 3+3's are a dime-a-dozen on Craigslist... http://bend.craigslist.org/cto/1299804607.html
Or just buy one that is already done: http://denver.craigslist.org/cto/1294471470.html
Offline bryan103
« Reply #11 on: August 23, 2009, 05:40:24 pm »
Because the truck is perfect,all new interior,crate motor and new paint,i dont mind the work,its what i do for a living.As long as the frames are the same in the front it should be easy enuff.
Offline Flamingbig10
« Reply #12 on: August 24, 2009, 01:00:38 am »
I would find a donor 1/2 2wd truck for the the front cross member, steering components, rear suspension and also a good 1/2 ton  rear end
Offline bryan103
« Reply #13 on: August 24, 2009, 10:12:03 am »
I bought a 82 2wd swb and gonna swap parts,make the swb a 4wd and sell it
Offline maddog
« Reply #14 on: September 01, 2009, 06:28:05 am »
I just looked at this post and ask why ? I have done just the opposite 2 wheel to 4 wheel if everthing works good just unlock hubs and let her free wheel, you could even pull front drive shaft out.
