Author Topic: 383 oil pan  (Read 5651 times)
Offline Just-speed
  • 84K10 350/700r4
383 oil pan
« on: July 05, 2009, 06:04:32 am »
Guys,
I am ordering a Blueprint engine 383 from summit this week. I have put my parts list together for what I will need. Really it sucks to have to change so much. I have added the Balancer and flexplate that I will need along with my new Cam and lifters, head gaskets, New head bolts.  The Problem is I know I cant use my current Oil Pan but also cant find one. Summit lists one Oil Pan that is for a stroker but its way to much money.  Any Idea which pan will work?   I do not want a stock steal pan that I need to ding to make work. Thats crazy.  My truck gets the crap beat out of it.    Any Oil Pan Idea's?
Looking forward to the new powerplant.   383 with Flat Tops. Performer RPM 64 cc heads, Performer RPM cam and Performer RPM intake.
Blueprint says with the 64 cc heads I will have 10:38/1.   I am thinking I will be around the 420hp mark.  I hopr the Perfromer combo pays off well.     I have everything figured out but this Oil Pan.        Lord I will I could use my Balancer and Flexplate off my 350. I hate knowing I have great parts I cant use anymore.
Engine Specs: Block:
 Seasoned, hand picked 4 bolt cores, max bore .040 (69-79 drivers side dipstick)
Cylinder wall thickness "Sonic tested"
Cylinders bore angle corrected to be 90° perpendicular to crank centerline
Cylinder bore centerline corrected to be exactly centered over crank centerline
Decks machined parallel to crank centerline
Right and left side decks machined equal distance from crank centerline
Main bearing bores align honed to correct size and straightness
Cylinders computer honed to tolerance of 200 millionths of an inch
Cylinders plateau finished for virtually instant break-in
Screw-in oil galley plugs installed in place of soft plugs
Rotating Assembly:
 Standard or 10-10, select castings only
Blacklight magnufluxed
Stress relieved and shot peened
Indexed and stroke corrected during grinding
Oil hole chamfered for improved flow
Super "micro-polish" for superior finish
Cylinder Heads:
 Not included - compression ratios for possible heads are:
Head Size / Compression Ratio
58cc / 11.11:1
64cc / 10.38:1
68cc / 9.96:1
72cc / 9.57:1
76cc / 9.21:1
A Ton Of Extras:
 Balanced to within 2 grams
Let GM go belly up! I got what I wanted. Thanks for building the best truck ever.
Offline eventhorizon66
Re: 383 oil pan
« Reply #1 on: July 05, 2009, 02:22:00 pm »
Are you sure your current oil pan won't work?  I bet most people that build a 383 DON'T use a stroker specific oil pan and don't have any issues.
'85 C10 SWB 350 700R4 TKO600
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: 383 oil pan
« Reply #2 on: July 05, 2009, 02:30:17 pm »
I thought a regular 350 cid pan works.  I didnt think they were different.  Of course, I bought my 383 from arizona and it came with an oil pan, so i never tried my 350 pan.
if a 350 pan wont work, seems a 400 will if the bolt pattern is the same as the 350 block....that is if there is some clearance issues for a stroker using a 350 pan.
Re: 383 oil pan
« Reply #3 on: July 06, 2009, 12:48:23 pm »
There is no special oil pan for a 383, just use the one that came on it.
