Author Topic: SM465 Questions  (Read 32137 times)
Re: SM465 Questions
« Reply #15 on: April 02, 2013, 09:24:28 pm »
I am having trouble with reverse it pops out  especially it you give it gas it wasn't as bad before but it now pops out quicker and easier what could it be?
     Stenny, it is more than likely a bad bearing, problem with the shifter or the internal fork for reverse.  It is more than likely worn and needs replacing.
« Last Edit: April 02, 2013, 09:27:17 pm by bake74 »
Offline stenny
Re: Re: SM465 Questions
« Reply #16 on: April 03, 2013, 09:53:08 am »
So you think that I can have it fixed  without taking the tranny out?
« Reply #17 on: April 14, 2013, 04:06:55 pm »
OP-
Are you sure you have the 465?
The reason I ask is because the 465's RPO code was M20
Did you see the date on the original post? The rpo he posted lists 4 forward gear manual trans.
Offline Engineer
Re: SM465 Questions
« Reply #18 on: April 21, 2013, 01:20:31 pm »
Looks like someone has run this thread through the laundry.
Why am I quoted in this thread even though I have no post in it.
Other than my post there is no RPO code in this thread.
« Last Edit: April 21, 2013, 01:27:55 pm by Engineer »
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline Flashback
Re: SM465 Questions
« Reply #19 on: April 26, 2013, 03:13:45 pm »
Yes, I am pretty sure I have the SM465. Its short and fat, has the PTO covers on the sides. Shift pattern:
L 2
1 3 R
Also, my pop-out problem has not gotten any worse in the 8k miles my truck has traveled since I got it. They have not been easy miles, these transmissions are tough!
1983 Malibu Wagon|TPI 305|T5 5 speed|3.73 non-posi
1992 Honda Accord Wagon|SOHC|5 speed|Gude Cam
1986 Chevrolet C10|305 V8|SM465|Shortbed|Custom Deluxe
