Author Topic: Hangers and a flip kit? Will this work?  (Read 19884 times)
Offline nico
« on: July 20, 2009, 02:45:48 pm »
My 84 SWB, see below, is currently lowered with 2.5" spindles, 2" hangers, 2" shackles and the thickest overload springs removed. I liked the look when it was on 15" Cragars, but since I've gone with Torq Thrusts, it seems a little high and has too much rake. The new shoes are 17x8 and 17x9.5 with 255/50 and 275/50 Nitto's.
My question is: Can I keep my hangers and then go with a 5" flip kit? I'm not sure what it would do to my pinion angle... What should I go with in the front to level things out: I'm considering 2" springs?
Is 5/7 too low for a static drop cruiser?
White 1984 Silverado - Factory Paint, Factory Interior, and only 25k miles...
SOLD - Tan 1984 Silverado - 383, 700R4, Detroit Locker & 3.73's...
Re: Hangers and a flip kit? Will this work?
« Reply #1 on: July 21, 2009, 12:02:46 pm »
A flip kit on top of the shackle/hangers will put the rear to low in comparison to what you can get the front for a driver.  5/7 is about as low as I would go for a conservative driver.  Plus added the flip will throw your pinion off big time.
I would put a flip and hanger on the back and spindles /1" springs to get about 3.5/5 out of it.  Of course you have to put the stock hangers back on.
Offline Flamingbig10
« Reply #2 on: July 21, 2009, 04:24:14 pm »
I would with 2" lowering leafs
Offline 69byrd
  • Haulin!
« Reply #3 on: July 22, 2009, 11:01:18 am »
x2  and I would like to say your truck looks sweet with the Torque Thrust on it.
Offline eventhorizon66
« Reply #4 on: July 22, 2009, 11:05:17 am »
Who makes good lowering leafs for these trucks?
'85 C10 SWB 350 700R4 TKO600
Offline nico
« Reply #5 on: July 23, 2009, 10:12:18 pm »
Thanks for the compliments everyone... I will probably pull the stock hangers off one of my parts trucks this weekend.
My original thoughts were: Shackles are -2, Hangers are -2, overload leaf is -3/4 = -5-ish
Remove shackles +2, flip kit -5 = -7 under stock
If I keep my spindles and hangers, and add 2" coils and a flip kit, I should be around 4.5/7... Perfect for my staggered tire sizes.
I'm not sure how low I want to go... I may end up adding stock hangers, flip kit and trimming some stock front springs until the rake is perfect.
Offline nico
« Reply #6 on: July 27, 2009, 02:15:53 pm »
After studying some of my leftover parts, I decided to swap the rear leaf springs on this project.  My other 84 had a set of light duty spring with new poly-graphite bushings already installed...
The tan truck was originally a Big 10 package with five leaves, including the thickest overload, and rode accordingly.
I swapped these springs for a set of standard light-duty springs with three leaves (minus the overloads) and the truck dropped well over an inch... Now, it has about around 5.5" of rear drop, 2.5" of front drop and is very close to the look I was going for...
Thanks to all those who offered advice!
Offline treepete
« Reply #7 on: October 13, 2009, 09:46:19 pm »
im sorry to bring this post back, but they always say to search before asking a redundant question...
did you happen to have pictures of your new setup since you did this work? I am in about the same boat.. Im considering a flip kit to lower my rear a bit, but not sure how to approach it because the PO has a belltech 3/5 on it already with the dropped shackles and spindles. can I do a flip kit still and some coils in the front? I just want to do another inch in the front and maybe 1.5-2" in the back.
Ive got a great ride now, si I can sacrifice a little of comfort to get that lowered stance om looking for.
thanks for your thoughts.
just throwin that out there.
1983 Silverado
1999 Yukon Denali
Other problem: Off-Road R/C.     www.rccorral.com
« Reply #8 on: October 14, 2009, 07:37:30 pm »
A Belltech 3/5 kit should be either spindles and 1" spring/flip OR they 3" spindles/ flip.
You can't put a flip on a flip...  If you axle is ABOVE the springs you already have a flip kit.
Offline 84stepside
« Reply #9 on: October 15, 2009, 04:09:08 am »
But is it possible to reinstall the stock shackles, leave the dropped hangers, then do a flip kit to get approx. 7 inches of drop? I just so happen to be contemplating this idea also. Will I need to do any adjustments for the pinion angle? Also, is having the axle above the leafs better for tire hook up?
1984 GMC Sierra 2/4 drop
1979 Chevy Cheyenne 4/5 drop
« Reply #10 on: October 15, 2009, 04:36:47 pm »
Axle above the leaf is just how you accomplish a flip kit, it is flipped to the top of the springs.
What exactly do you have first?
It is possible, but you will DEFINITELY have pinion angles to address using those together.
Offline 84stepside
« Reply #11 on: October 15, 2009, 05:08:53 pm »
Right now I have dropped shackles & hangers, which gave me approx. 4" of drop. I was thinking of putting the stock shackles back on which would bring me back up 2", then do the flip kit. Which I figure would be 2" hanger + 5" flip would give me 7". Has anyone done this? Also, is tire hookup better with the axle on top of leafs?
« Reply #12 on: October 15, 2009, 10:41:12 pm »
Yes you can, and you will need shims.
Where the axle is has little to do with hookup on a leaf setup.
Offline 84stepside
« Reply #13 on: October 16, 2009, 05:32:35 pm »
Thanks Capt.
