Author Topic: need curb weight 1979 GMC K20 4wd and gvwr  (Read 31276 times)
Offline jpegb
« on: July 21, 2009, 10:21:03 pm »
looking for the curb weight for 1979 gmc light duty 3/4 ton 4wd k20 with long 131.5 wheelbase,also need gross vehicle weight rating for same truck tag missing. i remeber it being in the 7000s range
Offline rmauto1
Re: need curb weight 1979 GMC K20 4wd and gvwr
« Reply #1 on: July 23, 2009, 07:42:55 am »
my 78 k20 with a big block, turbo-400, 203, d44, 14ff weighed in at 4800 pounds. I think the k20's were rated at either 7,200 or 8,800 pounds depending on how they were set up from the factory(brake size and springs). hope that this helps.
« Reply #2 on: July 23, 2009, 11:28:50 am »
Gross weight is determined by the options on the truck are you wanting an estimate? The range for a K20 was 6800-8400lbs, being light duty it would be on the 6800 side.
You can run it over some scales for Curb weight, but for an estimate it is about 4800lbs
