Author Topic: 85 k10 turbo diesel swb  (Read 13529 times)
Offline 4x4x4x
  • 85k10 diesel
« on: July 26, 2009, 10:10:32 pm »
here's my little red pu
1985 k10 swb
1995 6.5 chevy crate engine
banks sidewinder turbo system with 3" exhaust
slotted front brakes
SS rear disk brake conversion
rebuilt 700r4 (beefed up)
auburn gear posi traction with electric lockers f/r
411 gears
33/1250 Goodyear MTR tires
rancho shocks and rear springs (2 1/2" lift)
dick chepek rims
custom interior
head liner redone (by us)
rear bed insert
+ much more
we live in the Tacoma, WA area and have owned little red since 1996. Great running rig that tracks like a tank in 4 wheel drive.  Diesel runs good and gets over 22mph hwy.
85 k10 swb, 6.5 diesel. banks sidewinder turbo, 700r4, auburn gear ected limited slip/lockers f & r, 411 gears, front slotted disks, rear disk brakes, 4"exhaust,  cibie headlight and fog lights, rancho rear spring lift, rancho shocks, new ft. springs,
Offline cowboy63645
Re: 85 k10 turbo diesel swb
« Reply #1 on: July 27, 2009, 03:31:15 pm »
very nice!!  How do you like the 6.5?  From what I have heard the banks kit with the 6.5 is a nice little combo!
« Reply #2 on: July 27, 2009, 05:06:04 pm »
Nice!  Are you using the Sidewinder for the 6.2L on yours?
Is it a custom exhaust?
Offline bmaier
« Reply #3 on: July 27, 2009, 07:27:22 pm »
Nice pickup!
Offline 4x4x4x
  • 85k10 diesel
« Reply #4 on: July 27, 2009, 09:52:50 pm »
thanks for your comments.
the banks sidewinder turbo system was previously installed on the original 6.2 diesel.  it was a simple bolt on change to add it to the Chevy 1995 6.5 crate engine including the banks exhaust package.  all engine accessories were bolted on to the new motor.
were are very pleased with the driveability of our truck. the beefed up 700r4 works very well with the low pressure turbo system.
i estimate that the stock 180hp motor is now producing about 240 hp.  lots of torque and with the 411 gears we are right on with the stock speedometer and engine rpm.  (55mph on the speedo show as 55mph on my gps)
didn't list it but we converted the 4 headlight system to Cibie 165mm euro beam head lights.  we are also in the process of adding Cibie fog lights.
Alec
Offline DnStClr
« Reply #5 on: July 28, 2009, 10:57:03 am »
Very cool, Alec. Did the engine bolt right in without mods to the mounts or cutting the wheel wells? I love your project. Thanks for sharing.
Don
87 Chevy Silverado
« Reply #6 on: July 28, 2009, 12:03:12 pm »
The 6.5L is a direct replacement for the 6.2L so it should have bolted straight in.  The last year 6.2L and first year 6.2L are identical other than the bore.
Reason I asked is I have a 6.5L Banks turbo, manifold, hat, intake and have heard the placement makes it fun for installing in a 73-87(91).
Offline 4x4x4x
  • 85k10 diesel
« Reply #7 on: July 28, 2009, 08:22:58 pm »
the banks side winder fits right in with no modification to the body.  the air box draws fresh air from the front of the truck
the system is designed to add 60 hp to the diesel.
the only problems that i had (besides rebuilding the turbo) was with the two rubber plugs on the intake under the hat,  they eventually cracked replaced them with metal caps. and you can't change all of the glow plugs with out taking off the exhaust down pipe.  the turbo is a low pressure system for normal driving it is rarely on unless I'm using a lot of throttle like going up a big hill, or passing a car.  if you go to banks power you can download the complete installation manual for the turbo system.
http://bankspower.com/products/show/156/11
Alec
1985 k10 turbo diesel
« Reply #8 on: July 29, 2009, 05:19:50 pm »
I have one for the later model version (not 73-87) which I heard will fit with issues on the 73-87 trucks.
