Author Topic: SunPro tach super slow needle?  (Read 7986 times)
Offline 76_Scottsdale
  • I'd rather push my Chevy than drive a Ford
« on: July 29, 2009, 06:17:45 pm »
Hi all,
I installed a Sunpro Supertach a while ago and it has had the slowest needle I've ever seen on any tach. It's to the point where it doesn't even catch up to where the motor is revved. I have it hooked up the same as my last on to the negative side of the coil from my HEI distributor and the last one worked just fine. Any thoghts? Possibly a bad apple? I will contact Sunpro for possible warranty info.
Thanks
1976 Scottsdale K20
350 C.I.D.
700R4
NP205
2 1/2" Lift
305/70/R16 BFG MT
True Dual 3" Flowmaster 40 Series Exhaust
Offline Donut
Re: SunPro tach super slow needle?
« Reply #1 on: July 30, 2009, 04:19:23 am »
Has it always done this?  Double check all your connections.
I don't know what "a while ago" is for time (you did bump after 3 hours  :)), but I'd be looking at returning it if all my connections were good and installation is correct.
'73 Chevy K-20 ***SOLD***
350/tbh350/np205
'86 C-30 dually, 454/tbh400
Offline 78Scottsdale
  • Light Without Heat
« Reply #2 on: August 09, 2009, 02:16:32 pm »
I installed a SunPro Supertach II in my 87 Grand Prix, Did you make sure the little switch on the back of the tach is set to V8 instead of V6?
-The Garage-
1987 Pontiac Grand Prix 305 V8 - 67k Orig. Miles
-Looking To Buy-
1978 Chevy Scottsdale K20, 350 V8, All Stock, Rust Free Frame, New Paint, Beautiful Truck.
« Reply #3 on: August 11, 2009, 01:09:43 am »
Connections are good, switch is in v8 position, yes it has always done this from day one.
1976 Scottsdale K20
350 C.I.D.
700R4
NP205
2 1/2" Lift
305/70/R16 BFG MT
Offline Donut
« Reply #4 on: August 11, 2009, 04:43:37 am »
That's why I mentioned returning it.  I've got a Sun pro water guage that's heading back, it reports my water temp @160 max.  It might be believable except for the 195 deg. thermostat.  Store slip says 90 day replacement if defective.
350/tbh350/np205
