Author Topic: upper door seal?  (Read 20746 times)
Offline IdahoMan
Re: upper door seal?
« Reply #15 on: January 13, 2015, 03:58:19 pm »
Just how soft or firm are these Upper Door Seals supposed to be?
Mine is bent down and inward in a lot of areas and is causing the floor on the passenger side to be wet. They aren't in very good shape me thinks. I see that Chris sells some.
« Reply #16 on: January 13, 2015, 07:04:18 pm »
hey vile, i would greatly appreciate some pics.
Looks like I missed this request from 2009! I have some doors with them still I think and can probably snap a few pix.
« Reply #17 on: January 13, 2015, 09:28:07 pm »
The outer seal shouldn't be causing water to get into the floor.  That would be caused by the lip seal from the cab to door.
Not sure how to describe how soft/firm it should be on the internet, but it should be compliant.  If it is original, it is probably hardened.
Offline IdahoMan
« Reply #18 on: January 14, 2015, 12:52:39 pm »
Ok, the forum isn't letting me post pictures so I'll just ask a queation:
The cab "Lip Seal" and the Upper Door Seal:
Are they hard to install?
Is there a good brand?
Thank you.
Offline IdahoMan
« Reply #19 on: January 14, 2015, 02:06:49 pm »
Ok, it worked.
Here's the "Lip Seal". I thought it was in good condition, maybe not.
What are they supposed to look like new?  Mine are quite flexible, not dried out or anything. They have some "Dents"
« Last Edit: January 15, 2015, 05:54:59 pm by IdahoMan »
« Reply #20 on: January 15, 2015, 10:24:30 pm »
That bottom pic is the cab to door seal and it is hollow in the middle and is quite flexible.  Shut a dollar in the door in a few places and see if you can easily pull it out.  If so you aren't getting a good seal and the door may need to be adjusted at the latch or otherwise.
I sell Precision.  In my opinion it is the best..
Offline IdahoMan
« Reply #21 on: January 19, 2015, 12:48:09 pm »
The "scraper" seals at the bottom of the door windows, is there supposed to be a sealant/glue applied to them or do they just pop in? Mine are new and they don't seem to press against the window very well, and there is a large gap between them and the door frame.  >:(
« Reply #22 on: January 22, 2015, 07:56:55 pm »
They should have clips on them for the door panel and the metal door..
Offline IdahoMan
« Reply #23 on: February 13, 2015, 08:39:03 pm »
Yes.
Which brand do you recommend?
See the gap. Also some kind of green moss or something seems to like these.
« Reply #24 on: February 19, 2015, 10:36:12 pm »
The green stuff is mold.
Are you talking about the gap between the scraper and the door opening?
Offline IdahoMan
« Reply #25 on: February 21, 2015, 06:18:13 pm »
Yes. In the upper picture, right-center, there is a gap between the scrapper-rubber and door body.
Are my upper door seals supposed to be bent inward or upward flat against the body?
My interior needs work next. I suppose I'll have someone paint the door-jams for me, maybe get new seals for the door, body and windows if I can find OEM-quallity. I am going to restore the vent-windows and have the painter do them do.. or do it myself. New carpet maybe. It would also be cool to get a Safe (like a fireproof handgun safe) (or have one fabricated) that will fit right under my driver-side seat and bolt into the floor.. heaven knows I hate drilling new holes but who knows..
Now I have gone off on a tangent.
« Last Edit: February 21, 2015, 06:40:01 pm by IdahoMan »
Offline IdahoMan
« Reply #26 on: February 21, 2015, 06:41:26 pm »
How common is that, or did I just get a bad brand?
« Reply #27 on: March 17, 2015, 11:53:00 pm »
If it sits outside alot not uncommon for mold.
I don't think that is that bad for fit, you could probably bend it some to make it fit better.  I think my suburban that has factory stuff (old) is like that on one...)  It is late though so....
