Author Topic: f250 rims on 84 2500  (Read 9761 times)
Offline gold84gmc
« on: August 08, 2009, 08:19:39 pm »
will rims from a f250 fit my 84 c2500?
92 buick century custom 3.3L
Re: f250 rims on 84 2500
« Reply #1 on: August 08, 2009, 09:46:48 pm »
Up to a certain year, 1997 or older.  Sometime after that they changed some on the 8 lugs.
Offline gold84gmc
« Reply #2 on: August 09, 2009, 08:16:42 am »
its kinda hard to tell in the pic i have of them but they look like theyre from a 2000's f250 but im not sure...the guy that has them used to have them on an 88 gmc 2500 so im 99% sure that theyll fit because the 2500 bolt pattern for gm was the same for a while (dont know the exact years) but the deal im getting is $60 for all 4 rims with 4 tires(only 2 have tread, mt 285/75/r16) and all 4 center caps so its a pretty good deal and theyre the aluminum rims
Offline Donut
« Reply #3 on: August 09, 2009, 09:24:05 am »
That is a deal if they'll fit and are straight.
'73 Chevy K-20 ***SOLD***
350/tbh350/np205
'86 C-30 dually, 454/tbh400
Offline 79K20
« Reply #4 on: August 10, 2009, 10:55:16 am »
If they are from a 2000's F250 they WILL NOT FIT your truck.
If this guy had them on a 88 GMC 2500, they didn't fit properly on his truck either. Ask him if the had the lug holes re-drilled and tapered...?
Offline gold84gmc
« Reply #5 on: August 10, 2009, 08:07:11 pm »
no theyre not modified at all....like i said its hard to tell from the pic i have (cell pic) and i dont know much about fords so i dont know when they changed the rims...thats why im guessing theyre from 2000's
Offline jimbo
« Reply #6 on: August 10, 2009, 09:01:04 pm »
Can you post the pic?
Offline gold84gmc
« Reply #7 on: August 11, 2009, 07:33:24 am »
the first pic is the actual rims and the second one i think is the same style
Offline 79K20
« Reply #8 on: August 11, 2009, 10:16:28 am »
Need better pics to tell. The second pic is definitely the '99-newer ford SD wheel, which will NOT work on your truck. I can't tell about the first pic.
All older 3/4-ton and 1-ton trucks (GM, Dodge, Ford) use the 8-on-6.5in bolt pattern, but the 1999-newer Fords are 8-on-170mm (~5 mm larger diameter than 6.5-inches). Pre-99 Fords have the same 8-on-6.5 that GM and Dodges use. Not sure why they changed... The wheels look very similar, and they will even fit over the studs if you push hard enough...
Offline gold84gmc
« Reply #9 on: August 11, 2009, 04:15:06 pm »
ok thanks for the info...ill try to find out what year theyre from and sorry about the pic
Offline gold84gmc
« Reply #10 on: August 11, 2009, 07:16:28 pm »
ok so the rims arent factory ford rims like i thought they were...theyre aftermarket but they have been on a chevy,dodge, and are now on a ford...i think theyre on a 87-91 f250..so now i know theyll fit my truck
