Author Topic: Need help IDing an A/C component  (Read 5557 times)
Offline Prong
« on: August 10, 2009, 05:15:49 pm »
Do any of you guys know the exact name of this part? I suspect it cuts off the outside air when the a/c is selected. It sits in the passenger side cowl area under the cowl screen. I need to replace it due to the fact that the "hinge" area that allows it to open/close as required has almost completely broken. It came off of my 79 K10 with the factory air. I found one number stamped on it which may be a GM number: 6262685 -A Any help on locating a replacement would be much appreciated as well.
79 K10 SB 4x4 383/Th350
79 K10 LB 4x4 350/SM465
