Author Topic: 78 hydroboost brakes to 85 brake booster  (Read 5626 times)
Offline aussie
« on: August 10, 2009, 06:48:32 pm »
will a 85 brake booster  fit my 78 c10 where the hydro was?? what do i need???
 thanks
Offline aussie
Re: 78 hydroboost brakes to 85 brake booster
« Reply #1 on: August 11, 2009, 06:26:39 pm »
anyone?
« Reply #2 on: August 11, 2009, 06:34:35 pm »
Fit, yes. but you will be missing 2 of the mounting bolts for the diaphragm setup and you would need the booster and the rod.
Offline ccz145a
« Reply #3 on: August 12, 2009, 07:00:51 am »
And the hydro boost pedal to rod pin is in a different location so you'll need a pedal from a vacuum boost truck. This will give you the right presure and eliminate the return spring that the vacuum system does not like.
Offline aussie
« Reply #4 on: August 13, 2009, 07:40:10 pm »
thanks for the info !!!!
