rear axle flange bolt spec's
Topic: rear axle flange bolt spec's (Read 12526 times)
heyharris1
August 10, 2009, 07:55:33 pm »
hello all, I had to change a lug that broke on the rear drum of my truck, everythging went ok but cannot seem to find the torque specs for the bolts in the picture, i think they are called the axle flange bolts but not sure.
thank you
jim
Blazin
Blazin new trails!
Re: rear axle flange bolt spec's
August 10, 2009, 08:46:11 pm »
gooduntight! The other one I use is the " two grunt method "
Donut
August 10, 2009, 08:59:31 pm »
More precise than my "elbow pop" and for the larger ones "shoulder pop". Guess I'm getting old.
'73 Chevy K-20 ***SOLD***
350/tbh350/np205
'86 C-30 dually, 454/tbh400
DnStClr
August 10, 2009, 09:54:31 pm »
Naturally, the torque spec depends on the dia. of the stud and the material it's made of. A common spec for 1/2-20 studs is 77 lb ft torque when a grade 5 stud is used.
http://www.hotrodheaven.com/store/brakes/pdf/140-6293.pdf
Don
87 Chevy Silverado
78 Chevyrado
Z62 ON-ROAD
Site Supporters
August 10, 2009, 10:17:28 pm »
115 ft.-lbs
heyharris1
August 10, 2009, 11:20:51 pm »
ty for the info.
jim
79K20
August 11, 2009, 10:46:55 am »
Those are probably Grade 8's... For a 1/2-20, torque is 92 ft-lbs.
