Author Topic: all gauges died!  (Read 10617 times)
Offline screamin86
all gauges died!
« on: August 11, 2009, 01:18:01 am »
well the po of my truck had rigged up a bunch of extra lights in the cab and had run them through the stereo wireing....well one day i was driving along and went to change the station on the radio and ended up moving it (not secured right either) and when i did all my factory gauges other than the speedo quit working!  the next day the radio came out after it set fire to all the extra wires the po had ran to the added lights. now all i want to do is figure out if there is a fuse somewhere or is the damage worse? ive looked at all the fuses and everything looks fine. i do not like driving without having a working temp gauge and fuel gauge! i added a mech oil psi gauge and a tach so im good there but id like to get everything else working again. all the lights work just the gauges themselves dont. any helpd would be greatly apreciated!! thanks guys/gals
86 ta:lm7 hot cam boltons
Re: all gauges died!
« Reply #1 on: August 11, 2009, 05:28:51 am »
Check the fuse box for the gauge fuse.
Offline screamin86
« Reply #2 on: August 11, 2009, 09:02:51 am »
Well can someone tell me where the gauge fuse is!? Lol i cant find it in the block
Offline screamin86
« Reply #3 on: August 11, 2009, 08:11:32 pm »
Anyone got any ideas? Im at a loss! Ive looked all through the fuse block and under dash and found nothing.
« Reply #4 on: August 11, 2009, 09:25:25 pm »
One my 85 it is labeled Gage/idle, a 20 amp fuse right on the box under the dash...
Offline screamin86
« Reply #5 on: August 11, 2009, 10:34:45 pm »
Ill have to look again when i leave work...do you remember about where on the block its located?
« Reply #6 on: August 12, 2009, 05:27:39 am »
Around the middle left to right and about 4 rows up.
Offline screamin86
« Reply #7 on: August 12, 2009, 11:21:36 am »
Yeah i feel like a idiot! Lol i found it. The one that may cars have just says gauges! Gage/idel threw me off. I got it fixed now! Thanks for the help!
« Reply #8 on: August 12, 2009, 04:16:21 pm »
Glad I could help
