Author Topic: My 1979 Stepside, C10 to K10 conversion  (Read 12272 times)
Offline smitty77
« on: August 17, 2009, 01:43:29 pm »
Finally getting around to starting a thread on my ongoing project.  Like a few of us here, I bought a pickup with no real goals, just make a nice cruiser out of it.  And now I'm in so deep I wonder if I'll ever come out the other side.  It all started with the purchase of a 1979 C10 (Big 10) stepside for $900 that I could have driven home if not for the iffy brakes, so a buddy towed it to my house.  This is actually a truck for my son (if it lasts that long, he's 7):
As I got crawling around it checking what needed work, I found some of the front-end components were shot.  By the time I was done tearing stuff apart, I was down to the front crossmember.  Then the ideas started flying....  "If I'm going this far, I should lower it, put in a dual exhaust, maybe some motor work, etc."  This was going to be expensive to put back together.  Then the snow started to fly, and lacking a garage, progress ground to a halt.
Lucky for me, Craigslist never closes so I spent the winter scrounging for parts.  That's when I came across this beauty for $850, another 1979 Chevy Sport.  The bed and cab were toast, but it had a 350 mated to a 700R4/NP208 (not original obviously), 4" lift, good running gear, nice frame, and good fenders and doors:
So I figured "How hard could a body swap be?"  and began stripping this one down in late winter and early spring.  By mid summer I had sold the doors and fenders for $250, another $150 for a scrap run with the hacked bed, cab, and other parts, and was left with a frame, extra motor, and tranny/t-case that I didn't know the history of.
So I took to the task of putting in new brake and fuel lines and putting some POR-15 on the frame topped by some tie-coat primer and POR Chassis Black.  in the meantime I was offered another parts truck, a 1980 3/4 ton Chevy that had a rough body but good axles, a TH400/NP205 that was known to be good, good fenders/hood/doors and a SM465/NP205 to go with it - all for $250!  how could I say no?  :D  The same buddy towed that one to his place, and I cut the parts from the truck right on the trailer.  Two days later we towed it ot the scrap yard where they lifted off everything I didn't want.  I kept the tranny and t-case for my project, sold the axles for $300, and still have the hood/doors/fenders.  (Sorry, no pics of this one).
That brings us to the present.  now that the frame is prepped, I'm going back to tearing apart the first truck to finally move the body.  The first task is to get the known-to-be-running 350 out and cleaned.  I did this this past weekend, covering myself in grime.  But it's done, and I can actually get excited about forward progress again.  In the photo is my $100 engine hoist (I love Craigslist):
And a shot of the aftermath (the rest of me looked similar).  The photos don't do me justice.  The wife wouldn't let me in the house in the state I was in, but fortunately I hooked up a kitchen sink outside last summer (with cold and hot water) as part of our outdoor kitchen, so I made my mess there instead:
I hope to be posting more in the coming weeks with this streak of nice weather they're forecasting.  But just to be safe, don't hold your breath... :D
Offline hotrod24
Re: My 1979 Stepside, C10 to K10 conversion
« Reply #1 on: August 17, 2009, 02:06:49 pm »
nice project
1978 pontiac grand prix...
Offline Dirtydog
« Reply #2 on: August 17, 2009, 08:51:07 pm »
I am addicted to Craigslist :P
Dirtydog
Offline smitty77
« Reply #3 on: August 19, 2009, 07:15:23 am »
nice project
Thanks!
I'm slowly getting to that magical point where everything I do now is bringing the truck closer to running.  I went through 2 cans of Gunk Engine Brite and got most of the sludge off of the motor.  Looking at all of the oil on there, and the copious amounts of RTV I found, it looks like I'm going to strip the front and do a timing cover gasket and front seal, drop the pan and do the rear main, and replace the freeze plugs while it's out of the frame.  I also have an Edelbrock intake manifold and carb ready to go on there as well.
Offline smitty77
« Reply #4 on: August 30, 2009, 08:17:37 pm »
Got a little more done since my last post.
While cleaning the engine I found a small hole in one of the rear freeze plugs behind the flywheel, but it was a hole nonetheless, so it turned the freeze plug job from "a good idea" into a necessity.  After a quick run to advanced auto I had a set of freeze plugs ready to go in as I figured I may as well do all of them while the motor is on the stand, especially the ones on the back.  While trying to remove the big plug for the cam shaft I nicked up the very outside of the bearing surface.  Is this a cause for worry?  The marred surface doesn't venture under the cam at all, just the remaining 1/64" or so of the bearing next to the plug.  I'd don't have a photo since I put the new plug in anyway and will just "run it" and hope it lasts.   In the future, what is the best way to get this plug out?  Do you just replace them when doing a complete rebuild?
Aside from that I now have a mostly stripped motor on a stand - I'm leaving the heads on, hoping to do no more than a "cosmetic overhaul" for now since I have another block that I may rebuild later when the funds are there to do it right.  Hopefully this week's progress will include new front and rear seals to button up the fore/aft oil leaks, paint job with Vile-recommended Rustoleum Hammered Finish spray paint, and a new intake and carb which have been sitting in my basement workshop for almost 2 years now.  The weather looks promising, so I should be able to get a few things done.
