Author Topic: i need some advice and info on a rearend before im broke  (Read 4174 times)
Offline 1984 bad boy
« on: August 20, 2009, 08:23:58 pm »
i have 1984 k10 short bed with a 8.5 10 bolt rear i was wondering if i could use 4.11 gears out of a 10 bolt 8.5 car rear and also if i have a 700r4 od and 35/12.50/15 tires do u know if the 4.11 would be a good choice im really just looking for more get up and go off the line my engine is a 350 with about 300 hp an the tranny is a new gm goodwrench 700r4 and i have the np208 transfer case please help me figure this out before all my money is gone i really love my truck and want to hook it up a lil better thank you to everybody ;D
Re: i need some advice and info on a rearend before im broke
« Reply #1 on: August 21, 2009, 11:34:02 pm »
well what ratio you have up front, you want them to match. why not swap out the whole axle. with 35s you should be OK but i would worry about your OD giving out due to the tire size. if your looking for a truck to hook up i would go with a 4x2. i would assume the gears would be the same out of the car and truck if they came from about the same year.
« Reply #2 on: August 25, 2009, 06:24:17 pm »
i stay out of od for that reason and i cant afford to replace the whole rear and asfar as the front goes ive had it for 3 years n never used the 4x4 so im not to concerned with it just really need to kno if gears are interchangible
Offline oldredtruck
« Reply #3 on: August 25, 2009, 07:10:13 pm »
YES - as long as they come from the same series diff as what you have in the truck right now..( prob a 3 series..mine was) 4:11 should be good - what is in there now? 3:08 I'm guessing...if so - 4:11's should be pretty good...maybe 4:56's since you are running 35" tires?
85 shortbed...She digs it...
« Reply #4 on: August 26, 2009, 06:32:48 am »
I'm running 4.56 with 38's and at 50 its bout 2k had her up to 72 last night and she ran about 2900
