Author Topic: go kart lighting  (Read 5971 times)
Offline gold84gmc
go kart lighting
« on: August 21, 2009, 05:11:22 pm »
i just got a 6 hp Tecumseh go kart that has no lights on it...i was wondering how to hook up some lights to it(it doesnt have electric start)...any info would be good
92 buick century custom 3.3L
Offline Stewart G Griffin
Re: go kart lighting
« Reply #1 on: August 24, 2009, 12:40:00 am »
Why do you need lights?
Offline gold84gmc
« Reply #2 on: August 24, 2009, 09:41:00 pm »
i dont need them i would just like to have them
Offline 4x4orbust
« Reply #3 on: August 24, 2009, 10:03:02 pm »
not even sure it's a possibility.   try finding a 12+ wire with a voltmeter.   maybe something off the ignition?   there should be only a few wires (kill switch and ignition)
Offline gold84gmc
« Reply #4 on: August 24, 2009, 10:18:07 pm »
well theres a kill switch on the engine and one on the steering wheel...will the switch on the engine have a 12+ wire?..because i thought kill switches just ground the engine out....if i cant use power from that then there is nothing else on the go kart that gives off power...but ill try it
Offline ccz145a
« Reply #5 on: August 25, 2009, 12:29:16 pm »
The engine would have to have a stator under the flywheel for this to work, if it does not have electric start, then I doubt it's there. You could hook up a battery and just charge it every now and then.
Offline gold84gmc
« Reply #6 on: August 25, 2009, 12:37:44 pm »
ya i dont need lights so if i cant find something on the engine that has power then im not gonna hook up lights...but thanx for the info
