Author Topic: 9.50 on 8.75?  (Read 11660 times)
Offline 78Scottsdale
  • Light Without Heat
9.50 on 8.75?
« on: August 22, 2009, 11:24:20 am »
The tires on my truck now are 8.75x16.5, can I put a 9.5 inch wide tire on this rim? its a stock 78 K20 white steel wheel.
-The Garage-
1987 Pontiac Grand Prix 305 V8 - 67k Orig. Miles
-Looking To Buy-
1978 Chevy Scottsdale K20, 350 V8, All Stock, Rust Free Frame, New Paint, Beautiful Truck.
Re: 9.50 on 8.75?
« Reply #1 on: August 22, 2009, 12:40:27 pm »
yes I have done it in the past with no problems.
Re: 9.50 on 8.75?
« Reply #2 on: August 22, 2009, 11:30:49 pm »
some tire places wont do it, do to lawsuits if the tire fail they could say its because it was improperly mounted. from what i heard you don't want to go more that 3" more than your tire size
Re: 9.50 on 8.75?
« Reply #3 on: August 23, 2009, 09:27:53 pm »
Great, I just wanted to make sure with truck tires, I know people put 245/60R14s on their G Bodies while the stock tire size is 195/75R14 :D, I personally have 205/70R14s.
Thanks guys.
-The Garage-
-Looking To Buy-
Offline Da67goatman
  • Burban
Re: 9.50 on 8.75?
« Reply #4 on: February 01, 2010, 07:36:08 pm »
I changed tires from 9.50 to 33 12.50 16.5 and had no problems.  In fact they look awesome and provide lots of protection for the rims.  I used 6.75" wide rims too.
« Last Edit: February 07, 2010, 09:27:38 am by Da67goatman »
<Pitcrew>
Offline malibu795
Re: 9.50 on 8.75?
« Reply #5 on: February 28, 2010, 12:10:07 pm »
Thanks guys.
*raise hand....
dotn that 245/60/14 on 5" rim
also put 315/75/16 on a 6.5" rim
adam wildman
75 K25 383/400
Re: 9.50 on 8.75?
« Reply #6 on: March 01, 2010, 01:26:45 am »
so your saying you put tires that were 6" wider than your rims? how did they wear? or is that a typo
Offline Da67goatman
  • Burban
Re: 9.50 on 8.75?
« Reply #7 on: March 01, 2010, 10:27:44 am »
Its not a typo, I actually put 12.5s on 6.75 in wide rims.  They are wearing pretty evenly, the edges are wearing a slight bit faster than the center but i think that is due to the fact that i only run 28psi in them.  If I were to do it over I would use the 8.25 in wide rims and a spacer to eliminate the rubbing rather than the super skinny rims.
<Pitcrew>
Re: 9.50 on 8.75?
« Reply #8 on: March 01, 2010, 10:56:13 am »
I WIULD OF THOUGHT THEY WOULD WEAR IN THE CENTER MORE THAN THE EDGE
Offline malibu795
Re: 9.50 on 8.75?
« Reply #9 on: March 01, 2010, 09:45:20 pm »
dpeending on how much air pressure...
adam wildman
75 K25 383/400
