Author Topic: a wobble in the front  (Read 4402 times)
Offline 85BURBAN
« on: September 02, 2009, 03:44:24 pm »
ive had a slight vibration in the front for a couple of days,jacked up the truck and wiggle the driverside tire and noticed it moved almost like a loose rim does,after checking it out i noticed the whole assembly even where the axle goes in to the front differential had a good about of play talked to my mechanic he says it sounds like the hub and input on this especially how to fix it would be greatly appreciated
Offline joesgarage71
  • Wrench
Re: a wobble in the front
« Reply #1 on: September 02, 2009, 08:29:29 pm »
 first check the wheel bearings
Offline 85BURBAN
« Reply #2 on: September 04, 2009, 06:29:27 pm »
had my guy take a look at it it was the wheelbearing now its all set still having a driveline vibration problem will start a new post in the drivetrain section thanks joesgarage for the advice
  • Wrench
« Reply #3 on: September 04, 2009, 06:52:46 pm »
anytime
