Author Topic: What wire for courtesy light from headlight switch?  (Read 6277 times)
Offline BigBadJohn
« on: September 02, 2009, 05:16:30 pm »
Im wiring up a courtesy light and I need to know what wire from the head light switch is on when you rotate the pull knob alkl the way to where it "clicks"
Offline ron350
Re: What wire for courtesy light from headlight switch?
« Reply #1 on: September 02, 2009, 10:49:03 pm »
On my 1975 model that is head light switch pin #7 White wire.
When the head light switch is rotated all the way counter clockwise a switch makes contact supplying ground for the courtesy lights.
1975 C10 step side stock with 350 two bbl. & 350 trans.
Offline BigBadJohn
« Reply #2 on: September 02, 2009, 11:33:35 pm »
Yeah. I ended up finding it
I had to go get a relay as I had no idea the switch supplied ground
